D6 8U Father -Son Winter Project
Showing 1 to 6 of 6 results
cowboyofequipment
Send a private message to cowboyofequipment
Undercarrage rebuild in process. Here some pictures. Removed track frames from donor 9U, changing out parts, it had a broken recoil spring bolt. Removing the spring was a little exciting. Used a Bob Cat with forks to pop out spring. Welded on a new sprocket and looking forward to rebuilding track frame.[attachment=11096]100_1003.jpg[/attachment][attachment=11103]100_1010.jpg[/attachment][attachment=11102]100_1009.jpg[/attachment][attachment=11101]100_1008.jpg[/attachment][attachment=11100]100_1007.jpg[/attachment][attachment=11099]100_1006.jpg[/attachment][attachment=11098]100_1005.jpg[/attachment][attachment=11097]100_1004.jpg[/attachment][attachment=11095]100_1002.jpg[/attachment][attachment=11104]100_1011.jpg[/attachment]
Tue, Oct 25, 2011 8:06 AM
jaker65
Send a private message to jaker65
wow you guys certainly have been busy over there in the shop lately. im only part of the way there on my roller job on the old D4. im still waiting for the machine shop to make the bars that the rollers bolt to. i'll have to stop down sometime and check this out when you finish up! good job guys!
Wed, Oct 26, 2011 6:27 AM
cowboyofequipment
Reply to jaker65:
Nice to here from you jake. The 8u is a winter project 1 of 10,000 or so . I have another d6 at dads for parts, we removed the tracks and trackframes last weekend. Now for the hard part drilling and removing all the broken bolts and changing out rollers, springs, & idlers . The 8u is a good running machine but the undercarriage is a mess.. Will try to get more pics later.
Wed, Oct 26, 2011 8:22 AM
Lorne
Send a private message to Lorne
Reply to cowboyofequipment:
Hi fellas
I recognize some of those parts in your pics,
I have a 1947 D6 8U with a front mounted CCU. Please check out my last weekend activity on the link below.
http://www.youtube.com/watch?v=gmUSfxkU8K0
I was fortunate enough to have found the cat sitting in the scrub at my parents property, a quick tow with a MF1105 had the old cat purring.
Ive taken it into the shed and given it some TLC. Its not perfect. but its helping me make use of some otherwise useless land.
the pony motor does not work, there are a few decent oil leaks, its running hot, i cant get enough adjustment on the left brake. And i just Love driving it.
Lorne
Sat, Oct 29, 2011 6:33 PM
Thank you received: 140
Reply to Lorne:
Hi fellas
Lorne
Hi, Lorne.
You're hooked. I have maintained for a LONG time now that old Cats should be banned - - - on the grounds that they are addictive.
Sun, Oct 30, 2011 3:36 AM
Lorne
Hi, Lorne.
My wife agrees with your comments. she might be due for some new gaskets and a bit of a lube.
Lorne
Sun, Oct 30, 2011 5:23 AM
Reply to Lorne:
Lorne
Hi, Lorne.
Quote:
"My wife agrees with your comments. she might be due for some new gaskets and a bit of a lube." Unquote.
Now if I understand your latest post correctly, you are telling us that your wife might be due for some new gaskets and a bit of a lube. Oughtn't that to be between your wife and yourself?
PLEASE, keep it clean. This IS a family forum.
Sun, Oct 30, 2011 6:42 AM
