D6 5r weight
D6 5r weight
m rust
Send a private message to m rust
What is the weight of a D6 5R serial number 5R 4888 Has a Laplant Choate hyd angle blade.Just trying to find out what ton trailer to haul it with.
Mon, Apr 29, 2019 8:25 AM
wimmera farmer
Thank you received: 10
Basic tractor is listed at 16300lbs so i would allow 20000lbs or 9 ton.
Someone will know the weight of that blade setup. Could easily be 100lbs of dirt in belly pan and undercarriage.
Cheers WF
Mon, Apr 29, 2019 6:56 PM
Reply to wimmera farmer:
Cheers WF
B-61 (straight blade) is 4,350 lbs.
R-61 (angle blade) is 5,100 lbs.
Mon, Apr 29, 2019 11:48 PM
