D6-5r engine oil filters.
Showing 1 to 10 of 10 results
Great southern land
Send a private message to Great southern land
Hi all I am after some part numbers for the oil filters on my d6. Now I read somewhere on this forum that if they don't have the T handles on top of them they are updated to full flow filters? I can't find that thread that I read that on so I am asking for some help
Trent
Forgot to right. It's a d6-5r 5494 with a d4600 engine.
Fri, Jul 31, 2015 3:10 AM
Mike Meyer
Thank you received: 6
Hi Trent, My 5R parts number book says the filter is 8B5755 though the filter tower in the book has the t handle, don't get excited, someone smarter than me will chime in soon, Cavpower in Adelaide show them in stock with a new part number 1R0729 at $23.09, so I'll guess that is the right filter number.
Mike
Fri, Jul 31, 2015 3:23 AM
Great southern land
Oh and if anyone has any idea on oil capacity would be great to.
Cheers
Fri, Jul 31, 2015 3:25 AM
Mike Meyer
Reply to Great southern land:
Cheers
My D6 Operators book doesn't give a quantity, nor does my Servicemans Reference book, the Nebraska Test results from the ACMOC Chapter 12 archive say they put 4.8 US gallons of SAE 20 oil in the engine, so that's about 20 litres, the book does say in hot conditions run SAE 30, otherwise SAE 20 is considered normal, someone will chime in with the exact quantity soon.
Fri, Jul 31, 2015 3:40 AM
Reply to Mike Meyer:
Main engine oil capacity is 19 quarts. SAE 30 for 32 deg. F.-up operation.
So what filters do you have, bypass (t-handle) or full flow (slotted hex nut)?
Fri, Jul 31, 2015 4:21 AM
Great southern land
My parts book turned up today. "Yay" but it only has the T handle ones in it. My tractor has the slotted hex nut.
Cheers.
Fri, Jul 31, 2015 1:50 PM
Mike Meyer
Cheers.
[quote="Great southern land"]My parts book turned up today. "Yay" but it only has the T handle ones in it. My tractor has the slotted hex nut.
Cheers.[/quote]
Don't worry about that, your parts book is the Master Copy, the best version you can get, just take the old oil filter to your nearest Cat Dealer or filter supplier and use the numbers off it to get a new one and move onto the next job, I assume you have a Operators Book to show you how to maintain her, if not get onto Fleabay again and let a few more moths out of the check book.
Fri, Jul 31, 2015 3:25 PM
Great southern land
Cheers.[/quote]
No I haven't got the operators book yet. Haven't found one for the right price yet. Lol.
Fri, Jul 31, 2015 5:16 PM
Great southern land
I do have the one for the d4600 engine but.
Fri, Jul 31, 2015 5:20 PM
Slotted Hex Head hold down bolt should be full flow conversion.
Uses a Cat #1R0659 or Wix #51161 element or pick one of several other interchanges.
Fri, Jul 31, 2015 9:55 PM
Great southern land
Thanks old magnet your a great help
Sat, Aug 1, 2015 5:12 AM
