d6-2h
rvopata
Send a private message to rvopata
i have a d-6 that is getting fuel in the crankcase and i suspect that it is either coming thru the transfer pump or the main pump.do any of you have any ideas where to start looking and was wondering how big a job it was to pull the injection pump off and repair,any
tips or help you can provide would be appreciated.thanks rudy
Mon, Oct 29, 2012 8:42 AM
Thank you received: 39
Do a search on the topic......was discussed not long ago.
Mon, Oct 29, 2012 10:15 PM
BillWalter
Pull the side plate off of the side of the pump housing and as the engine is running see if you can detect a leak around the lower part of each pump.
Mon, Oct 29, 2012 10:40 PM
rvopata
Reply to BillWalter:
thanks for the info bill and OM i will do as u said bill and got quite a better idea after i did a search OM.thanks again to both of u will let you guys know what i find.rudy
Sat, Nov 10, 2012 9:42 AM
