D6 10k final drive
D6 10k final drive
Showing 1 to 6 of 6 results
gordo
Send a private message to gordo
Can anyone tell me where my final drive oil is going? I don’t see it leaking anywhere but it’s low after changing it
Tue, Sep 25, 2018 5:46 PM
Top pinion seals are leaking oil into the steering clutch case. Have to remove steering clutches and seal and bearing cages for pinions.
Tue, Sep 25, 2018 9:00 PM
DPete
Agree, it doesn't seem possible but there is enough oil on the pinion to be sucked into the steering clutch compartment by suction created by the rotation of the clutch. Had it happen on a D8H. Make sure your breathers are clean
1962 D4C
Tue, Sep 25, 2018 9:28 PM
catsilver
First check the final drive breather tube, it exits to a breather in the rear end of the brake cover, these have been known to crack off inside the back end case, SLIGHTLY pressurise the final drive at the breather, remove the brake adjuster cover and see if any air is coming out.
Tue, Sep 25, 2018 10:17 PM
gordo
Reply to catsilver:
Ok I think I know what you are talking abou. I did notice that when walking the machine fast oil will come out breather tubes. Is this normal? Thanks everyone for the input!
Wed, Sep 26, 2018 12:24 AM
catsilver
Reply to gordo:
No its not normal, a couple of checks are required before tearing things apart to try and ascertain if its the breather tubes leaking/broken or by-passing the pinion seals, and if those breathers are blocked the final drive oil will be pushed through the pinion seals. We had a whole batch of D6C's in the mid '60's where we had to weld those tubes into the case though the top because they were welded inside the case and it was impossible for a welder to get all the way round from inside.
Wed, Sep 26, 2018 2:23 AM
gordo
Reply to catsilver:
Ok great. What do I need to do? Take the brake adjuster cover off and look in there for the breather tubes?
Wed, Sep 26, 2018 5:06 AM
