D5 POWER SHIFT has no deaccelerator
catsrbest
Online
Send a private message to catsrbest
I have a D5 95J powershift with no deacelerator. How should I go from forward to reverse? I have a D5 a few years newer and it has the deacelerator.
Mon, Sep 1, 2025 1:52 AM
Thank you received: 53
Hi, catsrbest.
Unless you want to go to the trouble of fitting a decelerator, the next best approach would be either to put the control lever in neutral, come to a complete stop and then select the next gear or cut the engine revs with the hand throttle, make your change and throttle up again. I used to do the latter with the Cat 941, 955 and 977 track loaders which had the throttle control right next to the powershift control - made it easy.
Mon, Sep 1, 2025 4:08 AM
