D5 Dozer brake problem
Rep0144
Send a private message to Rep0144
I have a D5 94J that I need to rebuild brakes on. Can the brake bands be taken out without removing inner parts and do the bands (that are made up 3 pieces bolted together), need to be separated to get them out. My service manual doesn't show removal except for lifting out complete with inner drum to change clutches.
Any help would be appreciated.
Russell
Sun, Jan 20, 2013 5:24 AM
Usual procedure is to break down into three sections and roll them out. Don't forget to back off the support screw underneath the tractor.
Mon, Jan 21, 2013 4:15 AM
Rep0144
Thanks, I was hoping that it could be accomplished that way.It probably will be fun to get everything cleaned up good with the pieces of the lining that peeled loose and are laying at the bottom of housing, but should be able to get it done.
Russell
Mon, Jan 21, 2013 9:18 AM
