D5 98J information needed
Showing 1 to 10 of 10 results
bursitis
what would be the year manufactured Horsepower and engine type of a D5 98J in the 600 serial number range?  what would the transmission group 8S2154 spec be?  Thanks
Mon, May 2, 2022 8:52 AM
Mschwartz
Online
Hello, 600 serial number I think will be 1969 or ‘70. Engine should be a D333C, about 500 tractors before the 3306. Transmission will be a 6 speed version, geared for ag work. Is your engine turboed? Horsepower ranges from 120-200 around here, just depends on who has been working on it. We need pictures. aMike
Mon, May 2, 2022 11:10 AM
bursitis
Reply to Mschwartz:
Thanks Mike---- yes it is an ag machine non turbo i think stated as 105 hp maybe a typo should be 150? or would the turbo be required for 150 hp? was there internal differences in the turbo engines different from the non turbo? or did they just add a turbo and adjust the fuel?
Mon, May 2, 2022 6:35 PM
Thank you received: 19
Reply to bursitis:
By my rack setting charts the 98J1-1133 uses The D333C engine non-turbo @ 120 hp. Same for the later D5B 3306, again non-turbo.
Transmission 8S2154 is a six speed, close ratio sliding gear type, same as used in the later D5B.
The transmission speeds are:
Forward
First 2.5 mph, second 3.0, third 3.5, fourth 4.0, fifth 4.6, sixth 5.6
Reverse
First 3.2, second 3.8, third 4.6, fourth 5.3
Turbo engines will have oil cooling jets for piston cooling.
Mon, May 2, 2022 11:44 PM
bursitis
Forward
Reverse
Thank You Magnet. so the D333C engine had two different blocks? one for non turbo and another for the turbo application? or could the piston cooling jets be added? was it common for a turbo to be added to these tractors configured like this?
Tue, May 3, 2022 12:35 AM
Reply to bursitis:
Cooling jets can be added, same block. The Special Application units did not originally come with turbo. but I guess it was fairly common to hot rod these units by adding a turbo. Certainly were other turbo versions in either the D333C or 3306 engines.
Tue, May 3, 2022 1:31 AM
bursitis
does anyone have a link to the Nebraska test on the Caterpillar D5?
Mon, May 9, 2022 5:31 AM
Reply to bursitis:
I got there very easy with google but the very quick look the last steel track machines I saw was a 1960 test. So no D5. But I only just tried once, but showed gas Cats and early stuff to 1960, then Challengers.
Mon, May 9, 2022 5:43 AM
bursitis
Reply to Ray54:
anyone have the performance handbook information on the D5 98J 600 serial number range non turbo six speed SA tractor? i am interested in the drawbar pull in the gears?
Sun, May 15, 2022 2:18 AM
Found this,
[attachment=67744]Cat D5 Specs 001.jpg[/attachment] [attachment=67744]Cat D5 Specs 001.jpg[/attachment]
Sun, May 15, 2022 3:49 AM
Found this,
This would be for the earlier D5, before the D5B and typical of the 98J
As found in Performance Handbook #7
 [attachment=67745]Special Application Specifications.jpg[/attachment]
Sun, May 15, 2022 7:06 AM
