D5 94J Final Drive issues - Flat tire?
Showing 1 to 6 of 6 results
kharville
Send a private message to kharville
Hi all. I feel like I should start a journal to chronicle all my issues so far into the Big Yellow iron ownership endeavor. I thought owning a boat was something. :Cry:
Anyway, after the minor issues I had last week with the D5 I finally got a couple of days to actually use it. It ran great all day long yesterday. As I was going to park it up for the evening I hear and feel a clunk from the left final drive. It felt like something you would feel in your car if you had a flat. Kind of a smooth then clunk as I rolled forward. (Imagine a tire in the shape of the letter "D".) I proceeded a few more yards and the pattern continued. It actually felt like the track would raise up on that size when the "clunk" happened again. I fear that some bearings or something in the final drive have went out. It was immediate the way this happened without any notice. I went from smooth operation to this crippled situation. I did not want to move it much in case I was destroying something further. Anyone ever hear of something like this?
Mon, Dec 31, 2018 8:49 AM
"If it sounds like a duck, and if it quacks like a duck, then its probably a duck" You probably have bearing trouble, see if you can wiggle the sprocket with a big pry bar.
Mon, Dec 31, 2018 9:21 AM
Thank you received: 93
by what you describe it sounds like the track chain may be stretched, that is has worn pins and bushings, or broken out bushings-- and every so often it gets out of synchronization with the sprocket teeth and the track jumps a tooth.
Often happens with good tracks too when they get choked between the links with mud or snow as the sprocket tooth cannot engage the bushing by enough to drive so it Pops--slips a tooth--weak or broken recoil spring could be a cause too.
Machines operating in trash, snow, mud often have holes cut out of the grouser plate between the bolt pattern to relieve the build up of crud.
Maybe get some one to drive the machine and you watch to see if this occurs, or you drive and someone watches.
Seem to recall driving machines into the shop that did this --they were there for new undercarriage.
Just a other possibility.
Video is of an excavator with mud choked track popping during travel.
https://www.youtube.com/watch?v=FrLQ2XAC_Nw
Hope it is as easy as this.
Mon, Dec 31, 2018 10:33 AM
kharville
Reply to edb:
[quote="edb"]Hi Team,
Eddie B.[/quote]
Eddie,
That is amazing that you would suggest that from my vague description. That is exactly what it is doing! I was operating in heavy mud all day long the day this happened. I guess I need to limp along back closer to the house where I can clean it up and see what is going on under there. Thanks for the insight. I might be mistaken but I think I'd rather have track/sprocket issues than final drive issues. That sounds more serious. Of course everything translates to $$$ these days.
Ken
Mon, Dec 31, 2018 9:45 PM
Reply to kharville:
Eddie B.[/quote]
Eddie,
Ken
Hi Ken,
way back when D6H's were the go there was a mismatch of sprocket segment tooth profile on some segments--this caused track popping with clean tracks but when gently going downhill and doing a gentle turn--took some finding and soon Cat had it sorted.
We had a lot of tip/trash/dump machines in our Dealer area and track packing was a problem for them even with trapezoidal holes--larger area then the usual round shaped holes in the grouser plates of snow plates.
Tue, Jan 1, 2019 6:30 AM
kharville
Reply to edb:
Hi Ken,
[quote="edb"]Hi Ken,
Eddie B.[/quote]
Good news! As I was getting ready to jack up the machine and review the issue I noticed the track was tight. I got up on top and walked the track and it did not sag. I thought maybe it is too tight. I released the grease fitting and about a handful of grease came out and the track loosened. I tried it and it drove great. Seems the excessive mud tightened the track. Lesson learned. Just like the manual says "adjust for your operating conditions ". Hahaha
Thu, Jan 3, 2019 10:58 AM
Reply to kharville:
Eddie B.[/quote]
track adjustment to the conditions is critical to undercarriage longevity--amongst many other factors-- the extra tension causes excessive wear and forces thru the entire system.
In Vietnam we had Inter TD15B's in our Plant Troop that we kept adjusted as instructed at our Plant Operators Courses. The track adjustment was ideal out on the sandy jobs we were doing, BUT, by the time we got back to the plant yard at night the tracks were running slack.
Under threat of a charge, our New Captain ordered the tracks tightened to spec. before we left the yard--I got down the track and loosened mine and then re-tightened them before reaching the yard--others did not--within a week we had one flogged out idler shaft/bearing and on another machine a broken track frame pivot bar.
Fri, Jan 4, 2019 5:40 AM
