D4K Engine Tappet Noise
Showing 1 to 10 of 12 results
Dick Tucker_archive
Send a private message to Dick Tucker_archive
I have a 2008 D4K that has a tappet noise after it is started and runs at idle after about 5 minutes. Could this be tappet noise? How do you adjust the tappets on this machine? The serial number is MMM00353.
Mon, Nov 5, 2018 8:57 PM
STEPHEN
I may be very wrong, but 2008 machine would have hyd tappets?
Tue, Nov 6, 2018 7:16 AM
jmvmopar
Reply to STEPHEN:
I don't actually know, but the Duramax does NOT have hydraulic lifters. So it's possible it has mechanical lifters.
Wed, Nov 7, 2018 6:13 AM
Dick Tucker_archive
Reply to jmvmopar:
Parts book shows mechanical lifters.
Wed, Nov 7, 2018 9:18 PM
Dick Tucker_archive
Reply to Dick Tucker_archive:
Ironman 3406 are you still out there maybe you can answer my question about setting the lifters on a Cat D4K machine?
Wed, Nov 7, 2018 9:21 PM
cojhl2
I'm surprised one can hear a tappet over the normal diesel noise. Are you sure it's not coming from combustion, ie timing etc..
Wed, Nov 7, 2018 11:02 PM
Dick Tucker_archive
Reply to cojhl2:
not sure what it is. When the engine is started and left at idle for about 5 minutes the noise starts. It sounds like a metallic rattle that has a uniform rhythm cannot tell if the rhythm pickups in speed as the engine speed is increased as the engine noise drowns it out. The oil pressure is good at 60 psig. I noticed this noise after I had changed the oil. I am running 15W 40 Shell Rotella. I have not run this machine more than 8 hours so it may have been doing this before and just didn't notice it. The machine has only 2300 hours on it and I just finished rebuilding the undercarriage on it. I first thought it was the air conditioner compressor but I turned it off and the noise continued.
Wed, Nov 7, 2018 11:23 PM
jstandle
Send a private message to jstandle
Reply to cojhl2:
Are you sure it's not an injector? We bought a D6C cheap once because the engine was knocking real bad, turned out to just be a bad injector and has ran fine since.
Jordan
Wed, Nov 7, 2018 11:25 PM
Dick Tucker_archive
Reply to jstandle:
Jordan
I guess that is a possibility. I have a D7 17A that had an engine knock because of an injector pump but it was a really deep sounding knock. With this D4K being a higher RPM machine I am not sure what an injector would do in regard to noise? This noise is a high pitch metallic sound. I though it might be a lifter since this machine has mechanical lifters.
Wed, Nov 7, 2018 11:54 PM
jstandle
If I recall correctly, the mechanic that diagnosed ours just started cracking injector lines listening for a change in noise.
Wed, Nov 7, 2018 11:56 PM
Dick Tucker_archive
Reply to jstandle:
I will try that and see if it makes any noise change.
Thu, Nov 8, 2018 12:07 AM
| Kingaroy, Queensland
