D4H just stopped.
D4H just stopped.
Showing 1 to 6 of 6 results
frictionman
Send a private message to frictionman
So I have a friend who has had a stroke and his health won't let him run his Cat anymore. I am clearing his fence rows for new fence building using his machine. At quitting time yesterday, I headed back towards my truck on the little D4H. I turned right and gave a small tree one more push into the pile, shifted into reverse, backed up and when I shifted back into forward... nothing. No forward, no reverse in any speed. Pulled the floor and the driveshaft is spinning. Oil is full and clean. Today I'll take a gauge in the woods and check pressures. Anyone else ran into this? No bang noise. Linkage is all in tact. Not how I wanted to spend the day.
Wed, Aug 23, 2017 10:20 PM
captainhowdy
Send a private message to captainhowdy
i am not trying to belittle you but let me ask a dumb question. did you check the park brake? are there any safety interlock systems that stop the tractor if you fall out of the seat?
Thu, Aug 24, 2017 2:00 AM
seiscat
Reply to captainhowdy:
Hello frictionman, checking pressures is the way to go. I had a a similar problem on a D6D 4X years ago and the culprit was a broken spring in the valve body. The spring was less than $15.00 from Caterpillar but I lost 2 days work.
Craig
Thu, Aug 24, 2017 2:18 AM
frictionman
The park safety was the first thing I thought of because it acts exactly like it is on, but it is not and wasn't moved when it happened. The tracks freewheel when the engine is running. It's linkage is also in tact. Thanks for the mention though. The only dumb question is the one that didn't get asked, right?
Thu, Aug 24, 2017 4:56 AM
657cat
Send a private message to 657cat
Reply to frictionman:
I would take the back cover off the transmission and see if one of the clutch test ports has come out.
Thu, Aug 24, 2017 12:07 PM
frictionman
Reply to 657cat:
This will remain a mystery. Went back today with gauges, fired it up and dropped it into gear and it moves. Used it pretty hard for 2 hours without a hiccup. I like it when they fi themselves.
Fri, Aug 25, 2017 9:21 AM
captainhowdy
i googled "my caterpillar D4H just stopped" and found quite a few results with similar to your experience. also have come to the conclusion the D4H isn't a very popular machine. am i right? what is wrong with the D4H SERIES?
Fri, Aug 25, 2017 7:05 PM
