Thanks Glum, that was quick!
I need part #13 plus the rod and ends.
I can make my own, but prefer the more robust OEM ones.
I got my 29X00827 from the king of D4Es himself, John G. Aka D4e...
A few little things, a good test drive and then to the painter it will likely go.
It’s a tight little machine with lots of power.
Thank you. JM![]()
JM or d4e, to the uninitiated such as myself, what makes these machines particularly desirable?
This machine is “one” of my newer CATs.
Lots if power with turbocharged 3304, agile and balanced. Power steering, etc.
In my area, this is only the 3rd one known to exist.
He has a commercial disking business that requires a full unit( tractor and disc) be able to be moved whole, as they changed job sites often daily. Nice and compact.
Various options depending on hydraulic system
[attachment=61357]20201205_045327.jpg[/attachment] [attachment=61358]20201205_045412.jpg[/attachment] [attachment=61359]20201205_045443.jpg[/attachment]![]()
One of mine in some mucky conditions yesterday. Nothing like wet sticky clay to have to dig out of track frames...
[attachment=61360]20201205_051518.jpg[/attachment] [attachment=61361]20201204_142625.jpg[/attachment]![]()
Thank you Glum! I will save these for future reference.
How well does the wheel tractor do with the 40? That’s wet I’ll say. Long distance or just conveniently using rubber vs. tracks?
Restored as a member
