D4D Sn 8301036
D4D Sn 8301036
AlanSmock-archive
Send a private message to AlanSmock-archive
I'm looking at a well used D4D Sn 8301036. Other than the standard stuff, anything I should look out for on this machine?
Tue, Dec 25, 2007 10:07 PM
Thank you received: 52
Hi 54D2,
I think you'll find that serial number to be an 83J1036, a 1970 model.
The engine is a late D330c, 4-3/4 bore, almost to a 3304(78P) engine at serial number 1822. By this time the D4D has it's bugs worked out and is a pretty good tractor.
Tue, Dec 25, 2007 11:59 PM
AlanSmock-archive
Hi 54D2,
Thanks for the information. I thought I'd pull an oil sample from the engine and trans to see if there is a major issue
Wed, Dec 26, 2007 3:43 AM
