D4D sn 7R503 Fluid Specifications
Showing 1 to 10 of 10 results
ceo-cdr
Send a private message to ceo-cdr
Good Morning all,
It has been a while since i have been on here adn i may be a little rusty with my typing, so bear with me. I have a Cat D4D bulldozer sn 7R503. I believe it originated in France as the decals, tags etc are in French. I would like to find out about it. What year is it? How does it compare with American serial numbers? What are the fluid specifications and capacities of this unit? ETC. Please post this information or point me in the right direction so that ii may find it myself.
Thank you,
Dave M.
Mon, Aug 29, 2011 8:26 PM
Thank you received: 60
The 7R D4D is made in France....power shift, LGP (1973)
#503 uses the D330c up to 7R508 then changes to 3304 (48V)
Unit would most closely compare to the US 83J prior to #2177.
Capacities are:
Cooling sys.......8 Gal.
Crankcase.........5 Gal.
Transmission....10 Gal.
Bevel Gear.........4 Gal.
Final Drives.......2.5 Gal. ea.
Fuel tank...........42 Gal.
Hydraulic control system....6.5 to 8.5 Gal.
At the time all compartments used SAE 30 for above 32 deg. F. operation
except for 10w in the hydraulic control system.
Mon, Aug 29, 2011 10:18 PM
ceo-cdr
Capacities are:
Thank you for the information Old Magnet. That was exactly what i wanted.
Mon, Aug 29, 2011 11:16 PM
ceo-cdr
Reply to ceo-cdr:
I am having problems with my left steering clutch. when i pull the lever, it goes to a detent and stays without activating the steering clutch. is this due to low or no fluid for the left steering clutch. the right sides steers peoperly. is that fluid seperate from the left final drive or is it the same resevoir?
Thanks,
Dave M.
Tue, Aug 30, 2011 1:00 AM
Reply to ceo-cdr:
Thanks,
Dave M.
Steering clutch compartment and clutches are dry, there is no hydraulic assist, just mechanical linkage and spring assist. Final drive compartments are separate. Have you run through the steering clutch adjustment procedure?
Tue, Aug 30, 2011 2:41 AM
ceo-cdr
No, i have not. when i purchased the unit, the previous owner said there was an oil leak that was putting oil on the brake mechanism. the left brake was always weak. i was running as i have been for 3 yrs and then next time i started it, no left steering clutch. I was under the impression that the oil was coming from a hydaulic assist umit and that it was dry. I guess i was wrong.
i do have the JenSales Operators, Parts and Service manuals, but the pictures showing the operator area show the steering levers on the dash and mine are on the floor. I will read the service maual more thoroughly and see if i can get the clutch adjusted.
Thank you for your replies Old Magnet,
Dave M.
Tue, Aug 30, 2011 3:04 AM
Reply to ceo-cdr:
Dave M.
If it's been that long have you removed the steering clutch compartment drain plugs and drained off what ever oil and water that might have accumulated.
Usual source of leakage is past the pinion drive flange seal, takes out the brakes and eventually seeps into the clutch plates. Can also foul things up so that they don't engage properly.
Tue, Aug 30, 2011 7:12 AM
ceo-cdr
No Old Magnet, i have not done anything with it. YES, i know i should be draining it etc. I did open the inspection covers under the seat and everything there seemed to be in place. right now when the left steering lever is pulled it cams over center and stays in place not activatinfg the clutch itself. Undortunately for me, i do not have the tools to undertake a m ajor teardown of this magnatude. Right now i have another problem, i overtightened the hydraulic track adjuster and am not sure how to relive the pressure. My Jensales manuals that i have show me how to remove and install the adjuster, but not how to djust it. They refer to the Lubrication & Maintnance manual, of which I do not have. Des anyone out there have one or could point me in the right direction to obtain one.
Thanks to all who can help this "novice" dozer owner.
Sat, Oct 8, 2011 6:35 AM
ol Grump
Reply to ceo-cdr:
Some of the hydraulic adjusters will have a plug that can be loosened to relieve the pressure, usually not too far from the zerk that you pump grease into. Others have the zerk going into a one way valve/bushing that must be taken out to relieve the pressure. Take a close look at yours and remove the zerk fitting carefully. .if no grease comes out look for either the relief fitting. .or carefully remove the bushing the zerk is threaded into.
Sat, Oct 8, 2011 7:52 PM
ceo-cdr
Reply to ol Grump:
Thanks for the info Ol Grump. I did some interenet searching and found a Lubrication & Maintenance Guide to download for my sn 7R503. I am very appreciative to all the help i have received fromthis forum. There is a lot of knowledge here.
Today i will attempt to relieve the pressure for the tracks. Yes i do have the relief valve seperate from the zerk.
I am still working on the left steering clutch and now i have a new problem, the output line of the hydraulic pump has a crack in it at the fitting near the resevoir. not sure how i am going to get that fixed. I think i will try to get the line off and see if a welding shop can fix it as i am sure there are no NEW lines available.
Wish me luck and again thanks for all the input.
Dave M.
Sat, Oct 8, 2011 9:56 PM
Taylor Bros
Send a private message to Taylor Bros
We acquired this dozer (SN 7R503) last year and have finally took the time this summer to work on it. We have rebuilt the steering clutches, replaced the pinion gears (chipped), and various bearings and races. I was just hoping to get more history as to how this machine made it to NE Missouri.
Dave, I would be interested in more information in what repairs you did to the machine and when you parted with it.
Thanks, Neal
Wed, Sep 3, 2025 2:51 AM
| Kingaroy, Queensland
