D4D Shift handles saga continues.
brucew
Send a private message to brucew
Well, this is getting to be fun. I went to town and went looking for bushings for the handles last week. Then I went looking for drill bits and the local hardware store doesn't carry anything over 1/2 inch any longer. So taking into account the cost of drill bits and the time spent playing with the handles, I asked about a local machine shop.
$70 later and one handle was brazed, both repaired back to round and a set of bearings installed in one handle.
Now comes the fun part of trying to twist the adjustment clevis on the steering cables which connect to the bottom of the handle. They are both frozen.
I guess the acetylene torch will get pulled out.
Once the handles are on, the Caterpillar 54 winch cable will be next. I figure 200 feet of 3/4 inch cable with a open spelter socket on the end. That will get the drum about 75% full and using 5/8 inch chokers, I figure damaging the main cable will be minimal.
Any other ideas for how to loosen the clevis?
Tue, Nov 19, 2019 7:48 AM
200 ft????? as I posted earlier The #54 winch capacity is 168 FT. You don't want to run full capacity unless you like bird nests.
Tue, Nov 19, 2019 7:57 AM
bursitis
12345678910
Tue, Nov 19, 2019 8:05 AM
brucew
If your old, I must be decrepit. Your right. 168 feet. So just to keep myself entertained, I will be going down to 160 feet of 3/4 inch. Figuring to always use 5/8 chokers, I anticipate the main cable should last a few years.
Tue, Nov 19, 2019 9:55 AM
| Hartley - South Australia
Newby Hall Tractor Fest
