D4D Help!
D4D Help!
Basdas
Send a private message to Basdas
Looking to buy this D4DI tried calling Cat, but they couldn’t help with any information.
serial# 83j773
cat put two zeros in #83j00773
looking for year and Stick or power shift or any other info would be appreciated!
thanks
Fri, Aug 16, 2024 3:55 AM
bruce oz
Thank you received: 23
https://www.acmoc.org/bb/discussion-d72/3476-opinions-on-83j-d4d-vs-96j-d5
Fri, Aug 16, 2024 5:40 AM
1969 model. power shift with D330C engine, direct electric start 65 hp.
Fri, Aug 16, 2024 9:12 AM
Basdas
Hey, thanks for the information I really really appreciate that.
I now find out he has to add water to the engine after he runs it a while, but he states it’s not going into the oil.
I would assume then that the compression is pushing into the radiator system and pushing out the water out of overflow tube?
Or is there a particular problem with the D330 C engine when it comes to losing coolant?
Any help would be greatly appreciated thanks
Fri, Aug 16, 2024 10:26 PM
Reply to Basdas:
Check for air bubbles at the radiator neck indicating either a head gasket problem or cracked head.
Fri, Aug 16, 2024 11:52 PM
