D4d front plate removal
Farm
Send a private message to Farm
[list=1]
[*]ho[attachment=74231]IMG_0158.jpeg[/attachment] [attachment=74231]IMG_0158.jpeg[/attachment]t
[*]how do I remove this?
[/list]
Tue, Nov 7, 2023 6:57 AM
Thank you received: 46
I am lost, but will guess any way. This is the front timing cover? Cat like threaded hole like the one showing top right. Put bolt in and use as pusher. But since I am only guessing that could be where they used a dowl to line things up.
But the real go to is the service mans reference book by Cat. Hopefully there is one in the library here if you are a paid member.
Tue, Nov 7, 2023 11:29 PM
Busso20
Thank you received: 23
Reply to Ray54:
Hi Farm, you may need to remove the front row of bolts on the oil pan as well they possibly go thru the pan into the front cover, the bearing weld it a bit and shrink it if you can't access to knock out with punch, I know the later engines do have location dowels as Ray 54 suggested, this era of motor I don't know for sure, I hope it goes well, cheers
Wed, Nov 8, 2023 4:55 AM
Farm
Reply to Busso20:
I just determined I don’t need to remove the plate.
It must be installed during manufacture and never designed to be removed.
Wed, Nov 8, 2023 6:46 AM
