D4D - D330 front crank seal removal
DPete
I need to get a puller for this seal, not sure what will work as it is in pretty deep. Any suggestions on what will work? I hope to keep from mutilating the seal and digging it out piece by piece.
1962 D4C
Thu, May 17, 2018 11:12 PM
d9gdon
I have always screwed in a sheet metal screw to opposite sides of the metal part of the seal and use a slide hammer to pull it.
Thu, May 17, 2018 11:59 PM
DPete
Reply to d9gdon:
I was thinking this yesterday, weld up some way to attach to the screws, use largest screws possible.
1962 D4C
Fri, May 18, 2018 12:20 AM
Thank you received: 78
Reply to DPete:
Another vote for the screws method - works well. If you spray some freeze-spray on the seal, it'll shrink it just a tad. Any advantage you can get will help
Fri, May 18, 2018 12:32 AM
bluox
Or you can jack up motor and remove support to take out 3 bolts on trunnion and change seal on bench.
Bob
Fri, May 18, 2018 1:43 AM
DPete
Reply to bluox:
Bob
Stripped out 4 holes, was trying one more time before plan B and got it.
1962 D4C
Fri, May 18, 2018 4:24 AM
