D4D - 85A Electric shutoff
pmduke
Send a private message to pmduke
Hello all
Has anybody installed any electric shutoff solenoid to this D4D engine, either on the linkage or directly on the governor? The engine is being used to power a irrigation water pump
If so do you have a list of parts and procedure.
Thanks,
Peter
Tue, Aug 6, 2013 7:59 PM
Thank you received: 19
Here is the governor solenoid for the D330c engine s/n 2B1-up.
Wed, Aug 7, 2013 12:30 AM
OM has given you the shutoff solenoid, but, if I recall correctly you will need the Industrial engine shutoff adaptor housing to fit it up to your existing tractor governor housing.
Maybe OM has this in his Parts Book or can see if it is needed as I do not have any Industrial engine Parts Book's.
Wed, Aug 7, 2013 7:09 AM
Reply to edb:
There is no call out for an adaptor, appears to mount directly to the governor.
I'll post the governor diagrams a little later.
Wed, Aug 7, 2013 7:49 AM
With Eddie's tip off I suspect it takes a different governor group to mount the solenoid.
Wed, Aug 7, 2013 8:34 AM
Mike Walsh
The irrigation pumps with mechanical fuel shut off in the Santa Clara and Salinas Valleys were usually equipped with Murphy switches. I've posted a link below to an irrigation supply company selling these controls. There should be plenty of parts houses selling the same thing in Oz. If you have trouble finding the CAT parts, this may help.
http://www.irrigationsupplyparts.com/murphy-gauges-mechanical-panel/
Wed, Aug 7, 2013 9:55 AM
Reply to Mike Walsh:
Hi OM,
thanks for helping out yet again--that is the one I had in mind.
Wed, Aug 7, 2013 4:13 PM
pmduke
Reply to edb:
Hi OM,
Thanks all for your help with this. Much appreciated.
Peter
Mon, Aug 26, 2013 8:33 PM
bob
Send a private message to bob
Reply to pmduke:
Peter
[quote="pmduke"]Thanks all for your help with this. Much appreciated.
Peter[/quote]
There are two types of solenoid, one powers to run the other powers to shut down. They mount on opposite sides of the housing. Be sure to get the right one, power to run has a pullin and hold in winding and holds in at lower amps, power to shutdown uses high amps and will burn out if used wrong.
Later Bob
Mon, Aug 26, 2013 9:36 PM
Earlcoate Charity Open Day
