D4D 84J Rebuild help - Old Magnet??
Catmandu
Send a private message to Catmandu
Does anyone have cut sheets from the servicemans manual on timing of the countershaft, The head and rod torques.
We can't find our book
CMD
Sat, Feb 9, 2013 11:47 PM
What s/n????
Sun, Feb 10, 2013 12:13 AM
Catmandu
What s/n????
OM, I'm at the wrong shop, but for the torques and countershafts, aren't all 84J's with a 3304 engine all the same?
Thanks for getting back so quick Magnet
CMD
Sun, Feb 10, 2013 12:44 AM
Reply to Catmandu:
CMD
Torques are not a problem but there are some differences in timing fuel injection pumps on the D330c and the 3304's. Late 3304's can be checked with timing pin. early 3304's and the D330c's by timing fixture and tooling only.
3304's came in at 84J1526-up.
Do you need timing gear alignments also?
Added including balancer timing.
Sun, Feb 10, 2013 1:07 AM
catsilver
The countershaft or balancer shaft timing is the same on all D330 and 3304 engines, with no 1 and 4 at TDC the balancers will be at the bottom, if you lock the balancers at the bottom with 2 3/8" nc bolts in the hole in the centre bearings through to the hole in the balancers with the engine at TDC 1 and 4, then fit the oil pump, you can't go wrong, although you may have to slacken back the left side bolt a little to move the balancer if you are fitting the oil pump with the timing case already on, just make sure that the balancers are right at the bottom after.
Sun, Feb 10, 2013 1:50 AM
Catmandu
Reply to catsilver:
Thanks guys, thats the ticket. She'll be purring by Monday
Thanks again OM and Catsilver
CMD
Sun, Feb 10, 2013 5:20 AM
