D4D 78A flywheel clutch question
Showing 1 to 6 of 6 results
mdancy
Send a private message to mdancy
I have a D4D 78A with the oil clutch. My question to anyone is , can you pull out the flywheel clutch shaft to replace the shaft oil seal without taking the clutch housing off the motor? If I take the drive shaft with u-joints off will I then be able to pull the shaft out ?
This is my first thread so hoping it goes through.Thanks
Sat, Aug 23, 2014 5:42 AM
Thank you received: 52
Service manual says no, have to remove the clutch.
Sat, Aug 23, 2014 9:35 AM
Mervyn Pepper
Send a private message to Mervyn Pepper
most definetly have to remove the clutch mate. The flange is part of the shaft.
Roller bearing on the output end is most likely stuffed as well. Discovered all this when I pulled mine apart to replace seal.
Sat, Aug 23, 2014 5:01 PM
mdancy
Reply to Mervyn Pepper:
Thanks for the replies .
Read and reread my service manual before I asked which only shows the removal after taking housing off machine .
I had seen on another thread pictures of a 78A that was being taken apart for rebuild /restore by another member and he had pulled the shaft out and the housing is still on machine , but transmission had already been pulled.
His bearing also fell apart when he pulled it out.
Mine is D4D 78A1859 by the way
Sat, Aug 23, 2014 6:46 PM
Mervyn Pepper
Reply to mdancy:
yep; that's exactly the way it was with me too.
had trans out, and thought I could be cunning and leave clutch engaged. shaft should come out ok and just replace seal. But rear roller bearing collapsed so had to pull all out and do it properly.
clutch is a lot easier to do if gearbox is already out.
but still needed to fabricate a lifting bracket for clutch. makes it much easier. I left dash, tank etc all in place.
remove oil circulating pump prior to clutch and refit after clutch is installed. pump shaft can be bent otherwise.
Good little dozer that can still do a lot of work; 78A4848
Sun, Aug 24, 2014 12:00 PM
Mervyn Pepper
road I did with her [attachment=24748]DSC00422.jpg[/attachment]
Sun, Aug 24, 2014 12:04 PM
mdancy
Pepper
#1- Nice job on the road. Maybe I can be that good with a blade one day.
#2- like your ser# sequence (484😎 easy to remember
If I read your text right your saying you did pull the shaft out. My service manual does give the drawing to build an arm or lifting device to attach to the housing when removing from the motor.
Also will be redoing my rops later more like yours. Mine has the round top FLECO . Makes it a little tight climbing aboard.
Sun, Aug 24, 2014 9:11 PM
