d4d
Showing 1 to 10 of 12 results
wacuda
Send a private message to wacuda
hi guys im going to look at a d4d manual shift but it has no hour meter..the guy tells me its has worn out 2 sets of tracks..is that a lot of work for a d4??...it has new tracks -rollers- idlers and runs well...anything i need to look for apart from the normal wear & tear...thanks
Sat, Jun 6, 2015 8:31 AM
rturn3060
Send a private message to rturn3060
What was the application? If it was an ag crawler it could have any where from 10,000 to 30,000 hours depending on the soil conditions. If it were a dozer tractor you could likely gauge from exterior blems how it was treated.The dozer application has a much shorter undercarriage life usually. You mentioned the new undercarriage parts that should include rear sprockets also. D4D's all had hour meters in the dash so this sounds a little specious to me. If you are serious pick up oil sample bottles and a pump kit from your cat dealer and pull oil samples from both finals, rear case,clutch, and the engine then you will know as one cannot see inside these tractors. In my construction business we pulled oil samples yearly and avoided some very costly failures by catching failures early.
Sat, Jun 6, 2015 9:19 AM
wacuda
Reply to rturn3060:
hi when you say undercarraige does this mean tracks idlers etc or is it the chassis that wears out??
Sat, Jun 6, 2015 9:39 AM
wacuda
Reply to wacuda:
ok so i just went to look at it..it runs well but burns a "bit" of oil...also the steering brakes screech & squeal loudly and the turn action is grabby [owner says its from sitting] what do you think ,worn out brake bands ?..and the tracks are worn & dont fit the sprockets nice they are floppy..so what do you think its worth its in australia...been out in the weather as well...any thoughts would be appreciated
Sat, Jun 6, 2015 3:02 PM
mrsmackpaul
Reply to wacuda:
Im pretty sure there was an early series and a later series D4D the earlier ones had a weaker back end I dont know what the serial number changes were someone on here will chime in soon give a more accurate details than I can
Some photo's would help with trying to give a opinion on what its worth some close pictures of the walking gear tracks sprockets rollers ect with these older machines if the walking gear needs to be replaced it would cost more than the whole machine is worth things to consider
Paul
Sat, Jun 6, 2015 4:39 PM
Inter674
Reply to mrsmackpaul:
Paul
I've looked at a few and the prices range from 12500 to 28000 for a good one - but everyone needed work. They are a good machine but Tassie owners usually drive them to death. I think you would need to be buying this machine at 10k or less to allow for some major repairs, eg., engine rebuild and tracks etc.
As a guide a neighbour bought a D4D 'bargain' for 12k and proceeded to re-build the engine, the final drives, the clutch, the steering clutches and replaced the sprockets and tracks and chains (2nd hand) and a couple of rollers and seals and a rough re-paint and he LOST money on it. He was asking 30k but ended up selling it for less than 25k.
Sat, Jun 6, 2015 5:52 PM
wacuda
Reply to Inter674:
[quote="Inter674"]I've looked at a few and the prices range from 12500 to 28000 for a good one - but everyone needed work. They are a good machine but Tassie owners usually drive them to death. I think you would need to be buying this machine at 10k or less to allow for some major repairs, eg., engine rebuild and tracks etc.
As a guide a neighbour bought a D4D 'bargain' for 12k and proceeded to re-build the engine, the final drives, the clutch, the steering clutches and replaced the sprockets and tracks and chains (2nd hand) and a couple of rollers and seals and a rough re-paint and he LOST money on it. He was asking 30k but ended up selling it for less than 25k.[/quote]
I reckon I could live with putting a bit of oil in it but the violent grabby squeeling steering worries me plus the tracks are stretched &floppy ....im not going to work it that hard but I don't fancy spending all my time &money fixing it....im thinking 10k would be fair
Sat, Jun 6, 2015 6:45 PM
D4C Charlie
Send a private message to D4C Charlie
Reply to wacuda:
If the brakes don't just glide smooth and grab all at once I would be checking to see if the brake drums are loose on the splines at the final pinions, this is pretty common. Charlie
Sun, Jun 7, 2015 12:29 AM
wacuda
Reply to D4C Charlie:
they definately grab all at once &make a horrible squeeling noise----how hard is this to fix ?----im thinking that with all the issues it has maybe to look for a better one..he wants 20k for it
Sun, Jun 7, 2015 6:54 AM
Reply to wacuda:
Put some operating time on the brakes. Enough to knock the rust off the drums. Brake squealing is not necessarily a bad thing. Now if the pedals pulse when braking that's another issue.
Sun, Jun 7, 2015 7:01 AM
Wombat
Donor
D4D in similar condition to what you describe sold for 7,500 in Southern NSW about 12 months ago, the tractor you are looking at, definitely is not worth anything like $20K.
If you have to start fixing final drives and brake drum etc it all will get very expensive very quickly, you start out to fix one thing and end up fixing a whole lot more at great expense.
Mon, Jun 8, 2015 6:52 AM
Newby Hall Tractor Fest
