D4D 22C638 brake band removal.
Showing 1 to 7 of 7 results
Garlic Mom
Send a private message to Garlic Mom
How do you get to the second set of nuts holding segment two and three of the brake band together?
Pete got the first set of nuts out by fishing the band around and accessing them from the small rectangular cover on the back of the case. He can't get to the second set because if he moves the band all the way to the rear, the ears hit the steering clutch spring while the nuts are still on the bottom. When he moves the band all the way to the front, the nuts are still not accessible through the rear cover.
I'm tired of beating him without getting any results.
Thanks for any suggestions
Garlic Mom
Sun, Feb 15, 2015 8:49 AM
The section with the ears has to go out the top after the brake anchor is removed.
Sun, Feb 15, 2015 1:06 PM
Mike Meyer
Try a bigger bit a willow branch GM, obviously the one you are using to beat Pete with ain't big enough if the boy hasn't got it out yet, you know the deal by now, spare the rod, spoil the child!
It's 100F here today, reminded me of the night you locked me out of my room back in August after we had dinner together in Bakersfield, I was thinking I'd be sleeping with the dog there for awhile.
All the best
Mike
Sun, Feb 15, 2015 1:27 PM
catsilver
Reply to Mike Meyer:
All the best
Mike
You jam as many washers as you can in the booster spring coils, jam the clutch levers right back with some blocks of wood then take the booster springs out, you can then roll the brake bands back to get at the nuts and take the front section with the ears out through the top, don't forget to tie a piece of string to the lower section and drag it round the drum to help putting the bands back in.
Sun, Feb 15, 2015 11:09 PM
Paso Bob
Hey Pete, that D-4D has way too much paint on it for you!
Sun, Feb 22, 2015 11:14 AM
chuckb
Reply to Paso Bob:
I was thinkin that it is way too new and should be still under warranty from the dealer
Sun, Feb 22, 2015 10:49 PM
Anchor #5F6743
Ball nut #5F6848
Stud #5F6849
Thu, Mar 12, 2015 12:44 AM
IronworkerFXR
Send a private message to IronworkerFXR
Wow that looks like a lot of painful bent over work to get the bands out !.
Nice Pete, but way too much wheelbase for me to work with in my area, interesting binder job, I think my state boys would bust my chops over that though.
Sat, Mar 21, 2015 4:22 AM
