D4D 22C-464 Steering brake adjustment
bplunk
Send a private message to bplunk
Good Morning. I have the operators and maint. manual for this machine. To adjust the steering brake it shows taking the plate of the back below the fuel tank and turning the nut for adjustment. Ok I got that. But where is the screw and locknut located to finish the adjustment. The picture shows the man adjusting the screw but where is it at on the machine? I hope its not in the hole where the nut is... that would be tough.
Sat, Dec 3, 2016 10:45 PM
catsilver
Make the brake adjustment through the top cover under the seat, don't be tempted to stamp on the brake and try it before putting all the cover bolts back, you can bend the anchor plate and damage the casing on some early D4D and 951 machines.
The support bolt and lock nut is underneath, wind the bolt in (not too hard) until you can feel it pushing the brake band against the drum, then back it off about 3/4 of a turn before tightening the lock nut. This is the adjustment which gets missed and allows the brake band to wear out at the top only if not done.
Sat, Dec 3, 2016 11:46 PM
bplunk
Reply to catsilver:
when you say "underneath'" do you mean the plate under the seat or under the tractor?
Sun, Dec 4, 2016 12:01 AM
Richard~J~W
Send a private message to Richard~J~W
Reply to bplunk:
Finally a question that I *think* I have an answer for on here :eyebrows:
Underneath is bolt "3" on the diagram
You got to climb underneath the backend
[attachment=39194]D4 brake adjust.jpg[/attachment]
Sun, Dec 4, 2016 2:03 AM
bplunk
Reply to Richard~J~W:
Ok, got it. I just looked and there the adjuster is, right under the rear of tractor, one on each side.
Thank you guys for the help.
bplunk.
Sun, Dec 4, 2016 2:15 AM
Chapter 2 The Link Club's AGM
