D4d
Sthorpe
Send a private message to Sthorpe
Just bought a D4d serial 84J360. Brakes are way out of adjustment or need replacing. How do I look at the adjustment? Are these simple brake bands like the older D4’s?
Mon, Jan 19, 2026 11:15 PM
Thank you received: 62
The one I have operated, remove a plate under the fuel tank and the brake band is right there. The head of the adjuster is on top of the band. But the machine with no history you need to check screw that is under the band as well. It carries the band, so the top is not dragging. So time to look for the Operators Book and a Parts Manual as well as the Serviceman Book for your serial number. And since I have only been around the one model, other could be different.
Tue, Jan 20, 2026 4:06 PM
brian18a
Thank you received: 69
From the 84J parts book
Tue, Jan 20, 2026 6:09 PM
