D4c Series II question
Showing 1 to 10 of 18 results
DavidG
Send a private message to DavidG
I know this is a newer tractor, but I bought a D4c Series II which has a direct drive transmission. I bought an operator's manual from Cat, using the serial number, but the manual does not mention direct drive. Does anyone know the correct oil for the transmission? Thanks for your help.
Tue, Nov 12, 2019 8:04 AM
If the steering clutches and transmission oil is combined I would say 30W or 50W Cat transmission drive train oil. For oil clutch 30W Cat TDO oil.
Tue, Nov 12, 2019 8:48 AM
bluox
I thought the series II tractors are power shift? What is your serial #.
Bob
Tue, Nov 12, 2019 10:46 AM
DavidG
Reply to bluox:
Bob
The s/n is 7KG115, I believe. Don't have it in front of me, but pretty sure. It was a Georgia Forest Service tractor originally, so it was probably a special order. Sort of unusual setup, in my experience, at least. It has a clutch foot pedal on the left for the main clutch, and a brake pedal in the middle. Steering is all with the hand clutches, including the track braking. For my use, which is mostly plowing fire lines, plus a little light clearing work, it is ideal. It also has a winch on the front, which I had not seen before, either.
Tue, Nov 12, 2019 9:05 PM
bursitis
Reply to DavidG:
i had one like that once. it basically is a powershift tractor without a torque converter but rather a hydraulic lockup clutch. if i remember it took 30weight TO2 oil but you should confirm.
Tue, Nov 12, 2019 9:20 PM
Reply to bursitis:
7KGxxxx is listed as a PowerShift, 3F/3R, Planetary transmission, wet clutches and brakes, 2-pedal steering and foot operated decelerator, three valve hydraulics, single lever dozer control. That s/n would be 1991 production.
Alternate configurations of steering and brakes would be listed as Attachments in the Parts Manual which I don't have.
Tue, Nov 12, 2019 11:18 PM
bluox
Reply to DavidG:
So you have a gear shifter between your feet and a forward reverse lever under the steering levers ? Either PS or DD power train uses 30 wt. drive train oil.
Bob
Wed, Nov 13, 2019 12:19 AM
Reply to bluox:
Bob
D4C series ll brochure....
https://erbequipment.com/Aggregate/media/Erb-Equipment/Used%20Equipment%20Specs/372.pdf
Wed, Nov 13, 2019 2:44 AM
DavidG
The shift lever is between my feet. The forward/reverse lever is outside the left armrest.
Fri, Nov 15, 2019 10:17 AM
DavidG
Reply to DavidG:
5 forward speed and 4 reverse
Fri, Nov 15, 2019 10:23 AM
Reply to DavidG:
Check that s/n again. Seems you are referring to one of the Special Application units.
Fri, Nov 15, 2019 11:21 AM
