D4C Liners
D4C Liners
GarySkepper
Send a private message to GarySkepper
Rebuilding the engine on a D4C with D330 motor. A couple of the liners are low, does anyone know the part number for liner shims for this motor? are they still available from Cat?. My parts book doesn't show any shims or part numbers for them. There were shims in place when I pulled it apart but they disintegrated when pulled out.
Gary
Thu, Dec 31, 2020 9:51 AM
Thank you received: 36
Hi Gary,
Product Bulletin with liner shim numbers and thicknesses.
Service Manual specs. that apply to all Cat Engines for liner protrusion requirements.
Hope this helps.
Thu, Dec 31, 2020 11:01 AM
GarySkepper
Reply to edb:
Hi Gary,
Hope this helps.
Thanks Eddie,
Looks like I need the o.30" one, lets see if available here.
Gary
Fri, Jan 1, 2021 10:53 AM
Alexjfrench
Send a private message to Alexjfrench
Reply to edb:
Hi Gary,
Hope this helps.
Can you tell me where this info came from?
  [attachment=74273]Liner-Proj_-3306---D6C.jpg[/attachment]
Thu, Nov 9, 2023 11:33 PM
Thank you received: 52
Reply to Alexjfrench:
I probably posted that, came from the 3304/3306 service manual. Mostly applies to earlier engines as well but not necessarily all of the info.
Fri, Nov 10, 2023 3:10 AM
