D4C Hour Meter Location
jdwalkbehind
Send a private message to jdwalkbehind
I'm going to look at a D4C and wanted to know where the hour meter is located on these? Is it a similar design to the U series or does it have a newer style gauge?
Fri, Feb 5, 2021 11:15 PM
Should be on the right hand side under the injection pump, not 100 % sure though.
Fri, Feb 5, 2021 11:17 PM
Thank you received: 19
If it's a 78A series D4C the service meter is on RH side just below the main fuel filter housing.
Sat, Feb 6, 2021 12:25 AM
