D4C 40A3429 brake band assembly
cb1
Send a private message to cb1
Started to address the turning issue with the D4. Steering clutches work great, right steering brake not so much. Took 4-bolt plate off right back and found non-attached lining floating around. Band assembly is loose and probably could just be adjusted, however, the upper lining has separated from the band. Everything else looks good, some sand in the bottom of the box.
Anyway, anybody know a good place to get the brake band assembly. My downloaded parts manual calls for part number 7H3922. I tried CAT's online search and it took me to another number 8Y-6304. Not 100% sure that's correct, however, might have to give up a kidney to buy that set.
I know they can be re-lined and may go that route..
Any insight would be great. Other than this, the Cat is a great dozer so-far.
Thanks,
cb1
Wed, Oct 23, 2019 11:28 PM
Thank you received: 46
Any good clutch and brake shop should be able to fix you up and more than likely the brake pads will be bonded to the bands instead of riveted.
Wed, Oct 23, 2019 11:39 PM
cb1
These are riveted, but I can not see why they separated through the peep hole. Have to wait to get out. Then condition.
Thanks,
cb1
Thu, Oct 24, 2019 12:20 AM
Reply to cb1:
Thanks,
cb1
[quote="cb1"]These are riveted, but I can not see why they separated through the peep hole. Have to wait to get out. Then condition.
Thanks,
cb1[/quote]
I meant the new linings provided by the shop will be bonded.
Thu, Oct 24, 2019 12:44 AM
cb1
Thanks,
cb1[/quote]
Ahh, my bad, I got you,
thanks,
cb1
Thu, Oct 24, 2019 1:48 AM
