D47U Water Temp Gauge
1S1K
Send a private message to 1S1K
Hi all, I need to replace my water temp gauge on my D47U, per the parts book for serial #18212 the correct gauge would be 4F6220, anyone know where I can get one or if that number supersedes to something different. I did not have any luck with Ebay or internet search.
1S1K
Sat, Oct 2, 2021 11:08 PM
bursitis
i ended up getting a gauge that was calibrated for the correct temp range of the d4 from stewart warner . the face reads in degrees F and uses numbers rather than green yellow red.
Sun, Oct 3, 2021 12:00 AM
rax200
Reply to bursitis:
Hi 1S1K,
The updated part number for the temp gauge is 200-5220.
Regards
Sun, Oct 3, 2021 5:23 AM
1S1K
Reply to rax200:
Hi 1S1K,
Regards
Fantastic! Where can I find info like that in the future?
Sun, Oct 3, 2021 6:37 AM
rax200
Reply to 1S1K:
Hi 1S1K,
I have an account with Cat and when you add items to the cart like old part numbers, it up dates to the new number.
If you got to your local Cat dealer they also should be able to give you the updated number too.
Regards
Sun, Oct 3, 2021 7:07 AM
1S1K
Reply to rax200:
Hi 1S1K,
Regards
Cool, thanks again!
Sun, Oct 3, 2021 7:47 AM
| Kingaroy, Queensland
