D47U Water Pump Leak
Showing 1 to 10 of 47 results
blwatson
Send a private message to blwatson
My D47U #11867 has a anti freeze leak where the water pump meats the back of the fan pulley. It started leaking after I had worked it for a couple of hours and parked it. Put a bucket under it and collected about a gallon of antifreeze at a slow but constant drip. I have picked up a bit of info by using the "search" tool. Looks like there is a seal in the pump that can be replaced. I have not run it since then and have not had time to work on it. Will it cause additional damage to the water pump if I run it for a short period of time to move it from where it is parked now? Any advise from someone who has done this repair would also be appreciated.
Thanks,
Bruce
Mon, Sep 25, 2017 10:27 PM
Grease the water pump bearings and go ahead and move it. The leak should be coming from a weep hole instead of through the bearings and out around the shaft. The weep hole may be plugged with hardened dust and then the coolant has to go through the bearings.
Usually not too hard to replace the seal if you have a bronze impeller. The cast iron ones can be stuck hard enough to break if you put a puller on the outer edge. Using a steering wheel puller with bolts threaded into the impeller works better. Protect the impeller shaft threads from damage!
Mon, Sep 25, 2017 10:52 PM
blwatson
Thank You ccjersey for the advise and info. I will most likely be looking for some more help once I get a chance to take things apart.
Bruce
Tue, Sep 26, 2017 5:44 AM
blwatson
Reply to blwatson:
Bruce
The snow has melted in the high country so I was able to get to the D4 to start this project. I got the fan and water pump assembly removed and brought it back to town to work on it. I do have the brass impeller and was able to pull it without a problem. I would like to get to the cat dealer this week to order parts. I am looking for any advise about what else I should look for in the way of maintenance while I have the unit out of the machine. Is the seal assembly 4F4769 the correct part number? I have not done one of these before. I am going to post some photos that might help anyone else in the future. I do believe the leak was from the drain hole and not through the bearings. The bearings seem to be snug and ok.
Mon, May 7, 2018 7:38 AM
Reply to blwatson:
You have two grease fittings on the housing, that's a big NO!, grease pressure will build up and push grease out of the seal and fill up the fan pulley. Look in the parts book,[I don't have mine handy at the moment] for that serial number and order the relief fitting and the grease fitting. Also take note that for certain serial numbers the relief valve is either on the upper or on the lower position of the pump housing. Also I believe the lock for the impeller nut is supposed to fit down in the notch on the impeller.
Mon, May 7, 2018 7:59 AM
blwatson
Thanks Rome K/G, That was going to be another question I was going to ask. The bottom fitting should be the grease fitting and the top the relief valve according to my operation and maintenance instructions. They both looked like grease fittings to me and I am not sure what the relief valve should look like. Someone before me must have replaced it with the wrong fitting. I will try to find a replacement relief valve.
Bruce
Mon, May 7, 2018 8:14 AM
Thank you received: 78
Reply to blwatson:
Bruce
Cat has them Bruce. I just bought one a few months ago because I threw the one out on my D2 as I thought it was a mangle grease nipple. You can check if the center plunger pulls outwards just by pulling on it with your fingers - it only has a light spring in it
Mon, May 7, 2018 8:23 AM
blwatson
Thanks Neil, that is good to know. I will add it to my parts list. I have been trying to post the parts diagram with the part numbers and descriptions from my Parts Manual but the system says that it too large of a file. I know that I have seen them posted before. Not sure what I am doing wrong. It shows the lower fitting as part 3B8485 and the upper as 4B4550. The Housing is a 4F7747. I think the seal I need is 4F4769 but just want to make sure.
Bruce
Mon, May 7, 2018 8:33 AM
That seal number crosses to 4n7526 that is also used on a D6. I think you have a good number that probably fits the D4/D315 as well.
I recently purchased one from local CAT dealer and one from global parts zone for about 1/3 the cost. I did not like the way the cheaper one was made. It may be fine but it is different from the OEM. Though they are the same outward appearance, the bellows assembly with the carbon ring is loose in the brass cup. I am sure once the impeller is installed it will push the bottom of the bellows against the bottom of the seal cup and hold the minimal coolant pressure just fine, but I am used to the whole thing being glued together like the one from CAT.
One thing to check is that the face of your bronze impeller has not worn enough so that there is not enough to compress the seal bellows spring properly. A new impeller from CAT is about $160 but it will have a ceramic seat glued to the face. I have a standard type 21 pump seal I am planning to install in another D6 pump as a trial to be able to use impellers missing the ceramic seat or worn too much to use with the standard seal carbon ring running directly on the face of the impeller. I will try to get that finished up and post a thread discussing it.
Mon, May 7, 2018 9:30 AM
blwatson
[quote="ccjersey"]That seal number crosses to 4n7526 that is also used on a D6. I think you have a good number that probably fits the D4/D315 as well.
One thing to check is that the face of your bronze impeller has not worn enough so that there is not enough to compress the seal bellows spring properly. A new impeller from CAT is about $160 but it will have a ceramic seat glued to the face. I have a standard type 21 pump seal I am planning to install in another D6 pump as a trial to be able to use impellers missing the ceramic seat or worn too much to use with the standard seal carbon ring running directly on the face of the impeller. I will try to get that finished up and post a thread discussing it.[/quote]
Thanks ccjersey, is there a good way to measure or tell if it is worn too much. Without a new one to compare with and never having done one before it would just be a guess on my part. The surface looks good and has small smooth grooves worn in it that match the face of the existing bellows seal. If there is any doubt I guess a new impeller would beat having to tear it all down again later.
Bruce
Mon, May 7, 2018 9:56 AM
If you install the shaft, grease seals and bearings in the housing and then install the new seal in the housing, when you set the impeller down on the taper of the shaft, it should compress the bellows about a quarter inch or so. At least 1/8" would be required to get the full wear life from the new carbon ring face.
If you could spin the impeller in a lathe, I would polish the face of it to remove the grooving. Unless you can spin it, I would leave it alone.
Sorry, I don't have a D4 pump to measure up for you. If you cannot get the necessary compression of the bellows spring then you either need a new impeller or the retrofit seal I am going to try out.
Mon, May 7, 2018 10:37 AM
