D47U Fuel Pump Housing Oil Change Question.
TooManyIrons
Send a private message to TooManyIrons
I would like to change the oil in the Fuel Pump Housing and cannot locate a drain plug.  I looked at the part break down and the operator's manual, but I did not see any mention of a drain plug. Do I need to pull the bottom cover to drain the oil or is there a drain plug?
Thanks,
C. D. Hunter
Priest River, ID
Sun, May 29, 2022 1:53 AM
Drain plug for the fuel injection pump housing is low on the governor housing next door.
Sun, May 29, 2022 2:14 AM
TooManyIrons
Thank you sir!!! If it had teeth, it could have bitten me!
Sun, May 29, 2022 3:39 AM
