D47u Final Drive Over-filled?
Showing 1 to 10 of 10 results
James Hayes
Send a private message to James Hayes
Gentlemen, I need your help. I recently replaced the seals on both sides of my Final Drive. After reassembly, we mistakenly refilled the Final Drive before taking the machine off the jack stands. When we test-drove the dozer about 30 minutes, we noticed a drop of oil on the inside of a track shoe. It took a little while before we thought about the oil level being different with the tractor on level ground, as opposed to having the tail-end sitting on a 15x15 inch oak block! When we opened the filler cups, on the rear, oil over flowed quite a bit.
As both sides continue to weep a little oil on the inside of the track shoes, is it possible we blew out brand new seals? The oil level in the cups hasn't changed. What do you think?
I certainly do NOT want to replace the seals on both sides of my Final Drive, EVER AGAIN!
Sat, Jul 4, 2009 5:57 AM
ag-mike
i don't think u can blow those seals like u can roller seals. the fluid seeks level and u probably did overfill. i understand they may take a bit to seal. i think cat makes a big expensine wrench to tighten them up after running awhile if still leaking, i believe.
Sat, Jul 4, 2009 6:41 AM
Thank you received: 95
Reply to ag-mike:
Hi James,
as you know these seals are a cork facing on the bellows. The facing is set at an angle of 3 Degrees so that contact occurs at the outer edge of the facing. At the Dealer we always lightly sanded the facing on a sheet of emery paper on the surface table to get at least 1/16" witness mark around the outer perimeter of the facing for a positive sealing and ensure there were no dents in this area to cause leakage.
ag-mike has correctly stated that these seals, if not faced as described, take a while to wear/seat in, so I would operate it at present and keep an eye on the oil level in the F/D and the leakage rate should diminish.
Hope this helps.
Sat, Jul 4, 2009 10:33 AM
ol Grump
Reply to edb:
Hi James,
Hope this helps.
If you think the reason is over filling, put the critter on flat ground and remove the fill plugs, NOT the drain plugs. Any overage will run out so have a drain pan under each one before you pull the plugs.
Sat, Jul 4, 2009 7:57 PM
James Hayes
Reply to ol Grump:
Thanks Men! Based on your advice, I think we did over-fill the final drive.
ol' Grump, when we leveled the machine and opened the fill plugs, it did puke oil for a while.
edb, the Dealer parts man nor the mechanics ever mentioned lightly sanding the facing on a sheet of emery cloth. In fact, the service manager advised me to pump grease in the final drive instead of repairing it, since the machine was so old (1955)! Maybe next time...
Mon, Jul 6, 2009 9:13 AM
OzDozer
Reply to James Hayes:
The D4 7U doesn't have breathers for the final drives, which exacerbates the overfill problem. There is a breather on the transmission, but none for the final drives.
There isn't a huge volume of air space in the top of the 7U final drive housing, so an overfill would reduce that air space to a relatively small amount.
Once you start operating the tractor, the gear action generates some degree of pressure via the thrashing of the oil (when the final drive warms considerably, the problem increases).
If you've ever part filled a small container with warm water when washing, then placed the lid on, and shook it up .. then unscrewed the lid .. you were probably surprised at the pressure generated by the shaking. The final drive on the 7U is not much different. Maybe the final doesn't get the same violent shaking as you'd give a container .. but it gets a pressure build-up, regardless. That pressure has only one way out .. via the sprocket seal.
The later model and bigger Cats had final drive breathers, that mounted on the top of the rear housing, next to the steering clutch compartment covers, and which had tubes running from the final drives, through the steering clutch compartment, to the breathers, to vent them.
These breathers could get blocked with mud or dirt buildup, and you could end up with pressurised final drive housings. Regular cleaning of the top of the steering clutch housing is necessary with these tractors.
Don't come down too hard on the Service Manager, he's probably never seen or worked on a Cat older than 25 years .. or received training on old Cat drivetrain construction and repair. Cat and their dealers are geared to producing and maintaining new or near-new equipment, for construction, mining and industry .. and Cats 40, 50 or 60 years old are merely historic curiosities to them.
My nephew runs 25 near-new Cats and is only interested in the latest models at all times. He thinks we're all a bit nuts to be interested in running and fixing old Cats, that he thinks belongs in museums .. and maybe we are .. 😄
Mon, Jul 6, 2009 9:53 AM
Thank you received: 140
Reply to OzDozer:
Hi, OzDozer.
But it's a pretty nice 'nuts', isn't it, especially for those of us who are infected and can understand and enjoy it? He's the one who is missing out. LOL.
Hi, James Hayes.
You have been given the 'good oil' above by some pretty qualified people, some qualified by training and others by doing but all qualified.
I have my own thoughts on the service manager's idea of filling the finals with grease and they are not positive. Grease does not circulate like the gear oil that these finals were designed to run with and can leave both bearings and gears short of lubrication, especially when cold or in colder weather. A semi-fluid chassis grease like the (VERY) old Marfak OO might work for a while but it would still eventually cake up and hang to the sides of the housing and the gears, leaving the bearings and gears short of lubricant. Stiffer greases would be worse.
Mon, Jul 6, 2009 8:34 PM
James Hayes
Hi, OzDozer.
Hi, James Hayes.
OzDozer,
If I pressurized the Final Drives, and the pressure had only one way out... through the sprocket seal... Would you think I significantly damaged the seals?
Thanks!
Sun, Jul 19, 2009 9:44 AM
OzDozer,
Thanks!
Not likely you damaged anything.....seems I recall a recommendation to slightly overfill the finals when running side hill operation. There is another out for pressure if in fact that is the problem.....it's past the pinion drive seals which pukes oil into the steering clutch/brake compartment and can lead to brake and clutch problems if the leakage is severe.
OK, scratch the overfill recommendation...wrong tractor. That's for my Cletrac which shares the final drive compartments with the bull gear compartment.....still I don't believe you would hurt anything with slight overfill.
Sun, Jul 19, 2009 9:54 AM
OzDozer
OzDozer,
Thanks!
[quote="James Hayes"]OzDozer,
Thanks![/quote]James - No, leakage created by overfill wouldn't damage the seals. The major and regular cause of seal damage is wire or twine wrapped around them.
If you're dozing, and you see even the smallest piece of wire or twine caught in the tracks .. stop, jump off, and hit the wire with a hammer against the pads, cutting it .. so you can pull it out.
Leaving ANY wire caught in the tracks while you're working, is generally a guaranteed way of it ending up wrapped around the sprocket seals. If you stop and remove it, the instant you see it, you won't have any problems. This instruction was drummed into me with great regularity, from the first day I stepped onto a dozer at age 15.
Sun, Jul 19, 2009 11:31 AM
Gordon.
Send a private message to Gordon.
Reply to OzDozer:
Grease in a final drive ????????
Dont ever James. The bearings and gears rely on a coating of oil to protect them. The pinion bearings have to have a supply of oil carried up by the gears. Larger tractors even have an oil pump to distribute the oil. 30 and 50 Weight special transmisson engine oils (TDO4) are available from most good suppliers of oils. I know quite a few guys over in the UK that use gear oils but only upto EP 80W90 viscosity. Caterpillar over the years have tooed and froed a bit on the type of oil to be used in finaldrives. Obviously EP (extreme pressure) oils are best for the gears as was designed. Engine oils are better for the bearings. Some of the tractors that have large roller bearings are better suited to gear oil where as the smaller bearings like the taper rollers probably prefer engine oils.
Regards Gordon.
Sun, Jul 19, 2009 3:27 PM
