D47U Equalizer spring question
MHG
Send a private message to MHG
My 7u has two broken leaves in the track equalizer spring. Will a spring from a J or a T interchange? If the spring wont swap will the individual leaves work? The broken leaves are part #s 4B6014 and 4B6015. Thanks in advance for the help
Tue, Jun 8, 2010 7:04 AM
chriscokid
Take it to a heavy truck spring repair shop,
Mine had two broken leaves and they made two new ones and had me out the door in less than 30 min. cost was less than 100.00
Tue, Jun 8, 2010 6:01 PM
Reply to chriscokid:
In general, leaves can be interchanged but there is a varity of leaf counts and length dimensions. Can always be cut down if need be.
At least I have found it to be so between 2T and "U" model D4's.
Tue, Jun 8, 2010 10:28 PM
MHG
Thanks for the help
Wed, Jun 9, 2010 10:20 AM
