d47u Diesel won't start, fuel pressure low.
Showing 11 to 14 of 14 results
2
side-seat
Did you replace the rubber seals where the pumps set on the injection body? I do know that the original tapered o rings have been replaced with a fat round body o ring.
Wed, Oct 14, 2026 2:39 PM
Thank you received: 91
The so called tapered O Rings under the injection pumps start life as round fat O Rings--they squash to the tapered shape in time.
Regards,
Thu, Oct 15, 2026 12:32 AM
danda
Send a private message to danda
I did not replace the o-rings. Even still the diesel is starting now, when it wouldn't before.
I am wondering about these o-rings:
1. what are expected symptoms if they leak?
2. Can one use a standard o-ring, or it is some special thing only available from Caterpillar? anyone got a part number handy?
Fri, Oct 16, 2026 4:26 AM
The O Rings are P/No 2A3307 and would be fuel resistant. Leakage would show externally around the seal location area in the Injection Pump body--more so when pressurised by the transfer pump, pressure when the main engine is shut off would be fuel tank head pressure.
Dimensions are :- 0.312" ID, cross section Dia. 0.188".
Dimensions as found in my old Cat O Ring Book, Form No :- 717-35238, Dated 1963.
Fri, Oct 16, 2026 11:27 PM
2
