D47U 44 hydraulic system
Showing 1 to 10 of 11 results
Vance Nickerson
Send a private message to Vance Nickerson
Is it normal for the blade control lever to be the right handle? The steel lines connect with the two center ports on the front unit and the outside ports are blocked off. Really don't want to cross the linkage and the hard lines can't be moved so is this factory? Going to Ebay tonight to look for the 44 manual. If it matters it has the tank on the hood for scraper use I understand.
Vance Nickerson
Wed, May 19, 2021 4:10 AM
gauntjoh
Librarian
Thank you received: 5
Hello Vance, there are parts catalogues for No 44 hydraulic units in the new Technical Library on this website.
Wed, May 19, 2021 9:51 AM
Vance Nickerson
Reply to gauntjoh:
I downloaded and looked at them and it appears hooked up correctly I'll just take the torch and heat and twist the control rods to swap them so the left handle controls the blade.
Wed, May 19, 2021 5:39 PM
Thank you received: 77
Reply to Vance Nickerson:
Hi Vance, what is your other handle connected to? The other valve on a two valve #44?
Wed, May 19, 2021 10:08 PM
Vance Nickerson
It's a dual handle setup for scraper use. The left handle is for the blocked ports on the far right and left of the unit. The lines have been removed and some block off plates installed. I can message or email pictures but don't have the ability to downsize them at the moment.
Wed, May 19, 2021 11:12 PM
What's the concern?? Normally the right hand lever controls the blade which uses the two inner pipe connections on top of the #44 control.
Thu, May 20, 2021 12:27 AM
Vance Nickerson
Just wanted to be certain that's the way it is supposed to be. I was guessing the front blade control would have been the left handle. If its correct I'm happy thank you Old Magnet. Bought this as a project and have found it to be pretty useful around the farm.
Thu, May 20, 2021 1:10 AM
Vance Nickerson
Now that I know it's hooked up correctly I would like to see if anyone has the piping to add the extra service to the rear as I hope to locate a scraper in the Texas area to show behind it. I believe it could be made up with schedule 80 pipe and work fine but if I can find original tubing it would look better. Having spent several hours working it filling in a pond and leveling some other areas it's proven its worth. My biggest issue is going to be moving the seat back and up to suit my 6'6" 360lb frame with a little more room. Thanks to all of you over the years who have chimed in with awesome advice. My first Caterpillar project was a 22 that was way more than I expected and without a blade wasn't much more than a trailer queen when finished. Enjoying this D4.
Sat, May 22, 2021 8:33 PM
It's not too bad to adjust the seat Vance. Couple of pieces of 3x2 channel iron or box tube or 4x2 if you need it, and some pipe nipples to extend the fuel line. Not only do you raise the seat, but also drill holes further back in the extensions to mount the tank - up and back. I'm not tall (6, 220) but moved my D2 seat tank up and back and it's much more comfortable so this'll help you for sure. It can make the pedal push feel a little different; I'm thinking of some additional footrests.
Sat, May 22, 2021 9:14 PM
Vance Nickerson
Mine is the side mounted fuel tank but I was thinking along the same lines. Thanks
Sat, May 22, 2021 10:06 PM
willwingo
Thank you received: 8
The picture below is how I set up my 7U. The spacer is from the Hyster D4N manual to give clearance for the controls. It did not require any changes in plumbing for the spacer or setting the seat in the far back holes for the seat tank.
I am 5'16" tall and I have enough room for my feet to run the brakes fairly easily. No reason that you couldn't add additional holes or a higher spacer for more room, but that will require some plumbing changes for the fuel system.
[attachment=63321]Seat mounting.JPG[/attachment]
Sun, May 23, 2021 6:26 AM
