D47j Poney Motor
D47j Poney Motor
railroadjoe220
Send a private message to railroadjoe220
On my poney motor I have a dead cylinder on the right side.Can you remove the cylinder head with out removing the poney.
Thanks Joe
Thu, Feb 13, 2014 8:14 AM
Yes, but you must drain the coolant down before you do. Usually can reuse the head gasket without any problems unless it's damaged in some way. May want to spray it with some sort of sealant if you have any questions about it sealing rough spots on head or block surfaces.
Hope you find a stuck valve that can be tapped back closed after spraying with penetrating oil etc.
Thu, Feb 13, 2014 8:19 AM
| Kingaroy, Queensland
