D46U petrol fuel valve
Aussie John
Send a private message to Aussie John
Can anyone help me with the part number for the glass bowl, seal and brass valve as fitted to the Zenith fuel filter / valve assy in the bottom of the D4 6U pony motor fuel tank. What type of material makes a good gland seal on these valves?
My engine serial number is 6U8564 and my parts book is for the earlier 5Us.
Thanks,
John
Mon, Apr 22, 2013 2:43 PM
Gland packing....in a pinch, teflon tape............best is string for faucet stems with graphite in it ...........doesn't take much. Does the valve shut off completely?
Mon, Apr 22, 2013 9:01 PM
Mike Meyer
Thank you received: 6
Those parts are available from your local Cat. Dealer, but they are not cheap, I don't have a 6U Parts Number book, but my D4 5T book says the bowl is 9B4514, Gasket 9B4519, Valve Assembly 9B4510, that's a starting point.
Cat. Dealers have previously sold the complete tap with bowl for around $150 from memory, I'd suggest you call Tilly's up at Toowoomba and see if they have a aftermarket version. I just bought some new one's off Fleabay in the USA for about $18, I'm figuring I might need an adapter or two to make the threads work, but hey, a extra $5 I can live with.
regards
Mike
Tue, Apr 23, 2013 3:46 AM
catsteve
Send a private message to catsteve
Reply to Mike Meyer:
regards
Mike
they come up fairly regular on ebay. in varying condition for rubbish to new old stock. search for zenith fuel or caterpillar fuel
here you go.
http://www.ebay.com/itm/ZENITH-FUEL-FILTER-GLASS-SHUT-OFF-ASSEMBLY-/200916877738?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ec79441aa&vxp=mtr
Tue, Apr 23, 2013 5:49 AM
