D46U hydraulic pressure
captainhowdy
Send a private message to captainhowdy
I need to replace the hoses on my hydraulic cylinders. does anyone know what the working pressure is on a 1953 D4 6U with cat hydraulics
Fri, Jul 7, 2017 4:42 AM
Here are the hydraulic system specifications...
Fri, Jul 7, 2017 5:04 AM
captainhowdy
Thanks Magnet. 1000 PSI working pressure single braid should work fine.
Fri, Jul 7, 2017 5:25 AM
8C 361
Thank you received: 12
Reply to captainhowdy:
More important is the OD of the hose to work with the clamps.
Fri, Jul 7, 2017 7:49 PM
Thank you received: 291
Reply to 8C 361:
Yes, the O.D. For the old clamp style isn't too common I found; local shop did some welding on fittings so the hose could be crimped. Just because the I.D. matches, doesn't mean it will work safely. Captainhowdy, be careful about the hose; hate to have you injure yourself or anyone else for that matter. JM
Fri, Jul 7, 2017 8:30 PM
I would recommend a hose with more than 1000 psi working pressure--the relief is set at 1200 psi and just about every hose I blew was from a shock load on the system
Fri, Jul 7, 2017 8:54 PM
