D46U Fuel and Oil filter
Showing 1 to 6 of 6 results
Jim Gorter
Send a private message to Jim Gorter
Are replacement filters available for the old cat crawlers and where do you find them. D46U oil and fuel filters. Thanks, Jim.
Tue, Dec 9, 2008 9:03 AM
Both filters available from Wix/Napa. Lets us know if you get the 6U (Los Osos??)
Tue, Dec 9, 2008 10:52 AM
Jim Gorter
Thanks OM, Is the fuel filter a sock type? I have not had one apart before but had been told it was sock type. Do you have wix numbers handy. The wix site only showed the oil filter. What engine does this machine have? My first experience with yellow iron and all the model numbers are a bit confusing. Thanks and yes I live in Los Osos (Baywood Park) Jim.
Wed, Dec 10, 2008 3:42 AM
Reply to Jim Gorter:
Yes, I noticed that also....I wonder if Wix/Napa is getting rid of the fuel filter production for that item. Yes, they are the sock type.
There must still be some in the system Wix #33164 (NAPA 3164)
Oil filter Wix #51161 (NAPA 1161)
Engine is D315
Wed, Dec 10, 2008 4:12 AM
Engine is D315
The NAPA/WIX filter is a single filter so you purchase however many you need for your tractor and reuse or make new gaskets if needed. CAT would have a set of filters and the gaskets for the filter plate under one part number as a filter service assembly.
firekat says Baldwin F919-C is the same single filter as the 13164/3164. I thought they had a kit like CAT with all the filters and gaskets in it, but I don't know what the number is for your tractor.
http://www.acmocbb.org/ACMOC_BB/showthread.php?t=4805&highlight=baldwin+fuel+filter
Wed, Dec 10, 2008 7:36 AM
Jim Gorter
Thanks for the info. I am currently working out price with the owner and want to get my ducks in a row as far as what I will need when I get it home. thanks again, Jim.
Wed, Dec 10, 2008 10:00 AM
John from Fresno
ccjersey,
Baldwin did have a kit. It was F919-C4. Came with 4 filters and 2 gaskets. Baldwin chose to discontinue it about 1 or 2 years ago. I still have some kits. WIX also had the same kit, but it has been gone much longer. They also had a kit that had 6 filters.
John
Wed, Dec 10, 2008 11:40 AM
