D4600 piston erosion
Showing 1 to 10 of 11 results
eric jensen
Send a private message to eric jensen
When I was changing the pre chamber i noticed some erosion on the top of the cylinder 3/16 or a little more this motor might get 20 hours a year on it what do you guys think
Mon, Oct 1, 2018 6:07 AM
WA7OPY
Send a private message to WA7OPY
Run it till it fails, at 20 hr year it will out live you.....WA7OPY
Mon, Oct 1, 2018 6:15 AM
Reply to WA7OPY:
"now when your tractor runs like crap like this one, that's whats going on in there" https://youtu.be/Jmbw9gCGG04
Mon, Oct 1, 2018 6:54 AM
oldbeek
I would change that nozzle.That cut looks like centralized spray from a bad nozzle.
Mon, Oct 1, 2018 9:11 AM
Reply to oldbeek:
"ya got that right!"
Mon, Oct 1, 2018 9:16 AM
eric jensen
Can you still get reman injectors for it I have a nozzle tester can you buy parts for the inside I am looking for the part number for the copper under the injector hold down
Mon, Oct 1, 2018 9:08 PM
oldbeek
Reply to eric jensen:
the tip in the parts book is called a cap 2A5746 it doesn't show up on machinery trader search part . The valve shown as 7B8089, don't know if this includes the tip, 302 at Florin tractor in Sacramento CA. Only gasket shown just below a nut 2A5744 Florin has 77 of them. You have a test bench?? just check out the spray pattern. I shoot them at a piece of cardboard to see how they spray. I have a 9K3585 cat 12 that I am parting out if you ever need something. The engine is seized and I have not got into into see if there are any good parts.
Tue, Oct 2, 2018 9:10 AM
eric jensen
Reply to oldbeek:
Yes I have one of the hand pump testers I just half to see if it has the right adapter I just don't want to make the piston worse
Tue, Oct 2, 2018 6:19 PM
oldbeek
Should have evenly spaced spray pattern. Each pattern should be the same, size and volume.
Wed, Oct 3, 2018 9:14 AM
eric jensen
Reply to oldbeek:
Here are some pictures of the injector being tested it looks OK to me i think they we done awhile ago but i wouldn't have seen the piston untill the pre chamber broke
Fri, Oct 5, 2018 7:09 AM
eric jensen
Is there any one out their that can rebuild my injectors the stream doesn't cone out now that i have been checking them
Wed, Oct 10, 2018 7:03 AM
