D4600 part numbers.
D4600 part numbers.
Great southern land
Send a private message to Great southern land
Anyone have access to the part numbers for a head gasket for a d4600 engine? Think I will have to pull the heads on my d6-5r
Thu, Jun 25, 2015 4:24 PM
wimmera farmer
Thank you received: 10
From a 4R1 parts book 2 of 8B313 head gaskets. You will also need 8 of 6B6225 and 8 of 7B2419 seal rings for water directors. Take note of where the directors are aimed to put them back correctly.
There could be changes for your serial number so I hope someone else with the correct book can confirm.
I don't have a 4r or 5r so not sure where the oil supply to the top end went, could be external pipe.Some models had a couple of extra seals in the head gasket for oil supply lines.
Two heads will be more managable than an 8U 9U one piece they are a crane job if you are on your own. Not a lot of light parts on any of them.
enjoy
Thu, Jun 25, 2015 6:14 PM
d23j
Reply to wimmera farmer:
enjoy
I got an aftermarket set for one 5 years back will look for the part number for you, regards Andrew
Fri, Jun 26, 2015 7:29 AM
Great southern land
Reply to d23j:
Thanks guys
Fri, Jun 26, 2015 7:54 AM
Great southern land
Reply to Great southern land:
Thanks guys
I got Tilly's to send me all the stuff I need to do the heads.
Head gaskets were $30 each. Cheap as.
Tue, Jun 30, 2015 1:29 AM
