D4600 d4400 311?
D4600 d4400 311?
jthornton
Send a private message to jthornton
I was wondering if the pony motor is the same or similar with the d4600 and the d4400 and the 311 motor.
The reason I am asking is because I poled the mag and the pony motor starter of the d4400 and was hoping I could us it on my d4400 or my 311. Thx
Sun, Jun 10, 2018 11:18 AM
Thank you received: 61
No and No, The D4600 uses an impulse coupling magneto, The D4400 and D311 does not.
The D4600 starter is made up of mostly the same parts but the mounting indexing is different than the D4400 and D311.
Sun, Jun 10, 2018 11:45 AM
jthornton
Ok,thanks for the reply! So do you think with the correct mounting bracket for the starter it would mechanical work?
Sun, Jun 10, 2018 12:22 PM
gemdozer
Thank you received: 25
Reply to jthornton:
No interchangable parts from poney 4400 and 4600
Sun, Jun 10, 2018 4:20 PM
