D4400 Pony Motor Removal
Showing 1 to 6 of 6 results
MattRichardson
Send a private message to MattRichardson
Has anyone got any tips or special tools used to remove the rear fixing on the Pony Motor? (Donkey engine to us) The fixing sort of below the Mag. I can’t seem to get any spanner / tool to fit. Thanks
Sun, May 14, 2023 3:27 AM
bernie
3/8” socket with a swivel attachment, extension, and patience. Once you have it set in there, not too bad-
Keep safe-
Sun, May 14, 2023 6:56 AM
rax200
You need a 9/16 socket on a 3/8 drive with a swivel joint and long extension, works all the time.
Sun, May 14, 2023 6:58 AM
Thank you received: 54
Reply to rax200:
a racheting spanner is useful to undo the nuts under the cylinders. and have a spare incase the stud winds out with the nut. otherwise its a slow job with a open ender.
Sun, May 14, 2023 4:46 PM
MattRichardson
Thanks all for the replies, the 3/8 extension and swivel adapter got it off in no time. She’s in the air
Tue, May 16, 2023 12:37 AM
The_Shooters_Apprentice
Send a private message to The_Shooters_Apprentice
Reply to MattRichardson:
I just dealt with this today. swivel socket is better than an separate swivel piece if you have a set.
Wed, May 17, 2023 1:51 PM
bernie
Reply to The_Shooters_Apprentice:
Good job! You may need a little glob of grease in the socket to hold the nuts when you reinstall. Clean the mating surfaces well where she sits back on the main block for the gasket to seal well.
Keep safe-
Thu, May 18, 2023 5:22 PM
