D4400 injectors
D4400 injectors
Showing 1 to 7 of 7 results
ozdicko
Send a private message to ozdicko
Hi, does anyone have service information on the overhaul of the 4/1.4 bore injectors and a parts breakdown?
Thanks in advance.
Bob.๐Ÿ˜•
Wed, Feb 20, 2008 7:27 AM
How far into it do you want to get?? Here's some initial stuff....don't think there is much in the way of parts available unless someone has a stash in the out back๐Ÿ˜Š ๐Ÿ˜Š
Wed, Feb 20, 2008 10:02 AM
ozdicko
Bloody beauty "Old Magnet", just wot a bloke was looking for!!. Want to go "all the way" with the injectors. Just need the info as I have access to a fuel shop. Any sizes,drawings for the spanner that is used to remove and replace injectors in the head?
Bob
Wed, Feb 20, 2008 10:41 AM
D4Doug
Send a private message to D4Doug
Reply to ozdicko:
Bob
Did you want to replace the nozzles or the injector
Wed, Feb 20, 2008 12:06 PM
Reply to ozdicko:
Bob
You'll probably have to make your own wrench.....1-3/4 inch size.
I'll post disassembly/assembly instructions in the morning.....way past my bed time now๐Ÿ˜Š
Wed, Feb 20, 2008 1:30 PM
Attached instructions:
Unseating pressure is 1500 psi
Correct needle lift is 0.007 in.
Also some of the tooling used along with the test apparatus.
Wed, Feb 20, 2008 11:34 PM
ozdicko
Old magnet.
Absolutely fantastic that info, I'm indebted to you! The info you have is mind boggling and the fact that you are prepared to share it with our group shows us just how fortunate we are to have some one of your calibre in this club.
Once again "thank you". Regards to all. Bob๐Ÿ˜„
Thu, Feb 21, 2008 5:38 AM
Reply to ozdicko:
Old magnet.
Many Thanks......not used to getting such rave reviews๐Ÿ˜Š ๐Ÿ˜Š ๐Ÿ˜Š
Thu, Feb 21, 2008 8:24 AM
