D4400 injector leaking
Showing 1 to 10 of 12 results
1948catD4
Send a private message to 1948catD4
I changed a injector i and is leaking where the pen is pointing. (I borrow this pic from another post this is not my injector.) The injector was for a D4 4G and had the big nozzle end on it and i needed to change the nozzle end to the smaller 2T nozzle end and put my large holddown nut on it and I have the injector tight in the combustion chamber but it wants to leak fuel where the pen is pointing anybody have any ideas why it is leaking could I have something not right. I bought the injector new at an auction last weekend.
Sat, May 15, 2010 9:00 AM
SpragueM
I am not able to make your photo larger. Thus I cannot tell where the pen is pointing. Can you repost the picture?
Matt
Sat, May 15, 2010 9:19 AM
1948catD4
Reply to SpragueM:
Matt
ok will take a new pic of the injector i tried to make it bigger but i couldn't either. It's leaking at the point of the pencil.
Sat, May 15, 2010 9:52 AM
Thank you received: 93
Reply to 1948catD4:
provided you got the dowel in the cap nut to align with the slot in the nozzle body and no lint or dust in between the nozzle and the nut shoulders, the end plate and nozzle body, the concave/convex sealing surfaces of the nozzle and the injector body, also the nut torqued to 70 lb. ft. you should have no leaks for a "new" injector.
If the seat area is scuffed or had crud between the surfaces they will have to be lapped together and everything scrupiously cleaned and resassembled over again.
See sequence and adjustments posted below.
These things can be very finnicky to set up and get operating correctly for the inexperienced, I used to get get them sent to me from other Dealers to do up.
I do not know who does them now I have retired.
There is a special concave/convex lapping block set to redo the nozzle and body faces and also to do the concave in the end of the needle seat face.
Hope this helps.
Sat, May 15, 2010 12:52 PM
SpragueM
Reply to edb:
Hope this helps.
I second what Edb say's. They can be very tricky to keep clean on assembly. Everything has to go together within microns or internal leaks will result. Another thing that you need to be concerned about is the breaking pressure. Everytime they are apart the pressure needs to be checked.
Matt
Sat, May 15, 2010 8:05 PM
1948catD4
Reply to SpragueM:
Matt
cleaned everthing up reassembled and still leaks from there not as bad as it first did. i guess there is a dowel that is used as a lock for the endcap that goes into a hole on the injector body
Tue, May 18, 2010 5:15 AM
Reply to 1948catD4:
Hi Team,,
the nut lock dowel, L shaped and about 1/8" dia, is removed from the outside of the nut and is no longer used, the dowel I was talking about is punched flush into the nut, is about 3/32" dia, it protrudes into the nut and positions the injector nozzle within in the nut. If there is any crud at the shoulder inside the nut ,where the end plate of the nozzle seats, the nozzle will not sit square and will distort and leak.
You may have to lap the nozzle and the body together at their concave/convex parting faces, there is a special lapping tool to do these on and at times I have had to still lap the nozzle and body together to get a good seal--they can be finniky-- lap them with a figure of 8 motion as well as twisting back and forth until you can see a good surface contact--not easy-- use the finest engine valve lapping paste you can find. The propper paste is a true lapping compound but is usually only available in largish tubs here in OZ. and expensive.
Make sure you clean out all traces of the paste or the needle will stick and wear out real quick. You can also lap, on a flat sheet of glass, the flat faces of the nozzle plate and body. If the nozzle body to end plate face has dowels in they are usually not too tight and can be gripped carefully with a good pair of vise grips and rotated and pulled at the same time to remove them.
You have to make sure there is no scratches going across the faces but any are circular so they help seal. To do this just rotate a couple of turns after you feel you have a good true face, then clean up and inspect under a magnifier or magnifying glass, what ever you have will have to do.
Hope this helps.
Tue, May 18, 2010 12:44 PM
bruce oz
Thank you received: 23
Reply to edb:
Hi Team,,
Hope this helps.
hello 1948catD4 ,i made this info up from someones info they posted ,may help,bruce oz
Tue, May 18, 2010 4:36 PM
Reply to bruce oz:
Hi Bruce,
I believe he has a fuel leak and not a combustion gas leak where indicated.
Tue, May 18, 2010 4:43 PM
1948catD4
Reply to edb:
Hi Bruce,
yeah i have a fuel leak the fuel comes up the my penciel is pointing earlier in the thread. I took my old injector out and I used the spray valve retainer nut assembly from it and used the new injector valve assembly, and nozzel end and put it in the old spray valve assembly and tighten everything up and put it back in the precup and tightend down and when i fired it up it didn't leak right away then it started to leak. but the first time I put everything together the the flat nozzel end came off the valve assembly and didn't seal and i flatened the 2 little dowels on the bottom of the valve assembly thats when it leaked alot because it wasn't sealing so i took apart the other injector i have and used that valve assembly and nozzel assembly and but it all back together and not it takes about 5 to 10 mins to start leaking
I guess i better go have it checked out at the local desiel injection shop before i blow the tractor up and waste more desiel fuel . I took off the retainer cap assemblys with a pipe wrench making sure not to damage the cap and tightend them up with the pipewrench so i have noway of getting the 70 lbs torque that they require.
Anymore info would be a big help to me
Daniel
Wed, May 19, 2010 1:30 AM
1948catD4
Reply to 1948catD4:
Daniel
Man if someone had a video of how to repair these things i could do it myself. im better at seeing how it's done then reading how to do it .maybe youtube video or something
Wed, May 19, 2010 1:34 AM
