d4400 diesel electric set 44-20 S
Showing 1 to 7 of 7 results
nielske
Send a private message to nielske
This generator flowed me home! it appears to be a d4400 engine. with a 44-20 s generator.
There is no engine tag left so have to remove the paint.
Does someone have some info about specs etc?
I am not so in to the electrics but we would like to put it in use during our earthmoving events here in Holland.
So any help is welcom!
It has a pony on it but it is not build for a pony i thing becouse they blind plated the bendix, and the cooling canals are not conected.
Starting engine is a 12 volt starter.
  [attachment=72346]WhatsApp Image 2023-05-25 at 20.46.00 (1).jpeg[/attachment][attachment=72347]WhatsApp Image 2023-05-25 at 20.46.00 (2).jpeg[/attachment][attachment=72348]WhatsApp Image 2023-05-25 at 20.46.00 (6).jpeg[/attachment][attachment=72349]WhatsApp Image 2023-05-25 at 20.46.00 (4).jpeg[/attachment][attachment=72350]WhatsApp Image 2023-05-25 at 20.46.00.jpeg[/attachment][attachment=72351]WhatsApp Image 2023-05-25 at 20.46.00 (5).jpeg[/attachment][attachment=72352]WhatsApp Image 2023-05-25 at 20.46.00 (3).jpeg[/attachment]
Thanks Niels
Fri, May 26, 2023 2:00 AM
nielske
Today we had some time to work on the diesel electric set.
I found out some details.
Engine number 1S2291
44-20 s
Generator The louis allis co
22.2 kva 20 kw 1200 rpm
110/220 volt  1 phase
60 cycles
10.8 amps
no of line leads 2
exciting volts 32  amps 19
Generator number T30ks195
They took some numbers off, but luckaly i could find the stamped engine number
I started the diesel, and it runs good, has some carter pressure but not much. 4000 hours could also be 14000..
For now we can not get any output out the generator, and i don't exactly know how to wire it up. we want to run it 220 volts so we can test it.
If someone has some instruction manual for it? any help would be welcome! we really want this one to run!
[attachment=72407]WhatsApp Image 2023-05-27 at 17.26.00 (1).jpeg[/attachment][attachment=72408]WhatsApp Image 2023-05-27 at 17.26.00.jpeg[/attachment][attachment=72409]WhatsApp Image 2023-05-27 at 17.26.01 (1).jpeg[/attachment][attachment=72410]WhatsApp Image 2023-05-27 at 17.26.01.jpeg[/attachment][attachment=72411]WhatsApp Image 2023-05-27 at 17.26.02.jpeg[/attachment][attachment=72412]WhatsApp Image 2023-05-27 at 17.28.30.jpeg[/attachment]
Sat, May 27, 2023 10:40 PM
nielske
Reply to nielske:
44-20 s
60 cycles
10.8 amps
no of line leads 2
Video right here: https://youtube.com/shorts/ardyr6W4fG0?feature=share
Sat, May 27, 2023 10:56 PM
MattRichardson
Send a private message to MattRichardson
I have the twin!
My pony appears original but the whole unit has been repainted at some point and a lot of the plates are missing. The information on the generator element is useful mine needs a full refurb.
Please share any information you find,
Matt
Sun, May 28, 2023 3:58 AM
nielske
Reply to MattRichardson:
I have the twin!
Matt
Hee that's cool! It is the same setup! Mine ended up in the Danish army, I hope to get it giving output! I understood they used it for a radio transmitters group in the army
Sun, May 28, 2023 5:19 AM
Thank you received: 54
Reply to nielske:
yes id would say it was ex millitary maybe royal airforce from that tag on it.
Sun, May 28, 2023 3:49 PM
Kurt Bangert
Thank you received: 43
Reply to trainzkid88:
Can't be of much help other than to say - Those are cool! Good luck with them.
Mon, May 29, 2023 9:50 PM
nielske
Reply to Kurt Bangert:
Thanks Kurt! Still looking for some info on it!
Sun, Jun 4, 2023 4:10 PM
