D4400 cold valve lash
d2gary
Looks like at a very minimum I'm going to have to pull the rocker shaft to get the push rod out . If everything looks good I'll put the push rod back and adjust all the valves. My book says if not running to adjust when the pushrod is at its lowest point. Seems like I've read on the forum to add 0.010 for cold adjustments. That would put it at a total of 0.020 for cold adjustment. Does this sound about right and would the valves need to be readjusted after running and warm. Any insight appreciated. Thanks
Tue, Mar 10, 2026 7:12 PM
Thank you received: 227
I would begin with the required clearances and if you are more comfortable add a few thousandths, but yes, run the clearances when the engine is up to operating temperatures. That is standard on most engines with adjustable valve lash. - cts
Tue, Mar 10, 2026 10:42 PM
Add 0.002" for cold lash settings
Tue, Mar 10, 2026 11:16 PM
d2gary
Thank you both for the information. So sounds like 0.012 is gonna be really close and should get me running. I will definitely be doing it again if and when I get it running.
Well its going to run but who knows when or how deep the rabbit hole gets
Wed, Mar 11, 2026 1:35 AM
