D4 with rear ripper
D4 with rear ripper
Showing 1 to 10 of 11 results
https://youtu.be/1hmBebrDujM
Sun, Mar 13, 2022 9:41 PM
Busso20
Thank you received: 13
RomeK/G would this be an original ripper box fitted? it does look very similar to todays style ripper unit fitted to graders, obviously smaller is size, possibly closer to a 12g size machine? Yes I wish I had one on my machine. cheers
Mon, Mar 14, 2022 6:14 AM
Glum
Reply to Busso20:
Busso20,
It is a cat No.4 ripper, built for the D4's. I'm not certain it was available during the U series production, but most certainly from the mid 60's through to the end of the D4e production run.
Was pretty much standard on most D4D and E's destined for this part of the world.
Mon, Mar 14, 2022 6:57 PM
Busso20
Reply to Glum:
Busso20,
Glum, thanks for the info I will keep an eye out for one, cheers
Tue, Mar 15, 2022 6:46 AM
Shaban1983
Send a private message to Shaban1983
Here's the one I've seen on a D4 dozer for sale here in Melbourne Australia:
  [attachment=67153]IMG_20220213_175441_resize.jpg[/attachment]
Tue, Mar 15, 2022 12:09 PM
Reply to Shaban1983:
Hi, Folks.
If my memory serves me rightly, Cat did not make a ripper for the D4s until the D4D 'coz their back ends were not designed for it. They were considered to be an agricultural tractor for drawbar work and the bulldozer was simply an attachment. That changed with the D series.
That said, I have seen some pretty sturdy rippers fitted to earlier D4s, probably the strongest of which was fitted to a 2T and placed ZERO load on the back end other than the final drives having to pull it 'coz it was mounted entirely direct to the track frames and used the normal blade rams minus the blade for lifting and lowering. A very neat piece of work.
Tue, Mar 15, 2022 1:02 PM
Wombat
Donor
Hi, Folks.
The proper way to mount a ripper on these earlier tractors was to take the pull through to where the drawbar pulled from, usually a couple of long high tensile rods threaded at the back where they came through holes in the bottom of the backing plate. When the nuts were pulled up tight, all the load went through to under the transmission case where the drawbar pulled from.
Wombat
Tue, Mar 15, 2022 3:03 PM
Thank you received: 22
Reply to Wombat:
Wombat
The 58Dxxxx  #4 Cat ripper application is for the 7U and 955 - 12A Traxcavators but I see no reason it could not be mounted to earlier model D4's. As Wombat states the bulk of the pulling load is transfered
to the forward drawbar mounting. Kind of a rare item to find now and was more common on the Traxcavator.
I copied the same design when constructing the 3-pt hitch for my D4 "U" model.
[attachment=67160]DCP_0783.JPG[/attachment]
[attachment=67161]DCP_0825.JPG[/attachment]
Tue, Mar 15, 2022 10:37 PM
Shaban1983
Great photos, thanks! Was looking for something like this for my D4-7U.
Do you have drawings/dimensions for it by any chance?
Wed, Mar 16, 2022 4:07 AM
Sorry no drawings or dimensions. Kind of a one off fabrication. I do remember leaving about 1/8" space for shims between that lower bracket and the rear case mounting plate.
Wed, Mar 16, 2022 5:41 AM
Hi, Old Magnet.
Yep, the Cat 941 and 951 track loaders had the same arrangement, complete with shims to cater for wear so that you could keep the load concentrated at the drawbar pull point if wear occurred at the drawbar pivot pin under the transmission.
Wed, Mar 16, 2022 9:24 AM
