D4 will not start
D4 will not start
Showing 1 to 10 of 11 results
sweman
Send a private message to sweman
Hey! I have a D4 model year -1972 who do not want to start it comes no smoke from the chimney I think the gas trapped in stop mode, but I don't know .How takes loose injectors. Does anyone have suggestions
Sweman
Sat, Jul 9, 2016 4:29 PM
Andrew
Has it been parked for a long time???
Sat, Jul 9, 2016 5:20 PM
Try starting it with the throttle lever all the way the OPPOSITE way from how you have it now.........just a thought:redface:
If no luck with that, move it back.......HARD. have seen the linkage between lever and engine bind up and the governor lever not come out of shutoff position. May take a good strong tug to get it to move the governor.
Of course you might not be getting fuel TO the injection pump.......
1 no fuel in tank
2 valve turned off or tank outlet plugged
3 fuel strainer or fuel line plugged
4 fuel filters plugged
Check for fuel at top of filter by opening the bleed used to release trapped air. If you have fuel there while cranking the engine, stop and loosen a couple injector line connections and see if you get fuel flowing out there. Fuel will flow to injectors even when the governor is in shutoff position, but none will be injected into the cylinders.
If you have fuel to the injectors but it will not smoke white while cranking, the rack must be stuck in shutoff position.
Sat, Jul 9, 2016 8:04 PM
sweman
1 no fuel in tank
Hi! thank you for the answers.
I now have emptied the tank , changed the filter , new fuel and it comes out fuel before the injectors , but i did loose an injector and drove the engine but it will not comeout anything from the injector may have to test pressing them , when I run start gas in the air filter starts it up a little.
I started the engine 2 months ago and then it started immediately , looked at the hour meter 1946 hrs but i have started it a few times each year
Tue, Jul 12, 2016 6:54 PM
Bruce P
Reply to sweman:
Perhaps you have an internal fuel pump problem?
Stuck rack maybe? Or would this be a sleeve metered engine? Stuck sleeves maybe?
Good luck
Bruce P
Tue, Jul 12, 2016 8:00 PM
sweman
Reply to Bruce P:
Good luck
Bruce P
Hi and thanks!
It was the rack in the fuel pump that had been stuck in the stop position , so now I have put the governor together, and now runs the engine again it started almost immediately, but i see it leak a drop of oil, but I will fix it tomorrow.
Thu, Jul 14, 2016 4:18 AM
old-iron-habit
Reply to sweman:
Hi and thanks!
[quote="sweman"]Hi and thanks!
Thanks[/quote]
Good to hear you found the problem.
Thu, Jul 14, 2016 9:18 AM
greengiant
Send a private message to greengiant
1 no fuel in tank
If you have fuel to the injectors but it will not smoke white while cranking, the rack must be stuck in shutoff position.[/QUOTE]
for us newbies, what is the rack?
Thu, Jul 20, 2017 8:58 AM
Thank you received: 20
Reply to greengiant:
The rack is the gear toothed bar that rotates the injection pumps to meter the fuel.
Thu, Jul 20, 2017 9:23 AM
catsilver
If this is a sleeve metering fuel pump, they are prone to sticking in the shut-off position and breaking the overfueling spring which helps starting.
Thu, Jul 20, 2017 2:08 PM
catsilver
Thu, Jul 20, 2017 2:21 PM
